In need of sickle cutter bar
   / In need of sickle cutter bar #1
jacobsdaddy06
NW Arkansas
MF1240
Bought a new idea 256, 3 pt sickle mower obviously well used, well today the bar broke where it attaches to main assembly, anybody know where I might find one? Also would other makes fit or are there universal ones? Thanks
   / In need of sickle cutter bar #2
Not sure what you mean by the 'main assembly', but the bar backbones are usually just soft steel. Line it up using a tooth and bolts (If that's where it broke) slice out a section to fill with weldment, and have it welded back together. Even castings can be welded (nickle rod is my favorite).
A few pictures would make it more clear to us where the break is and the type of fix that could work.
   / In need of sickle cutter bar #3
Check that bar carefully--it may be bent by whatever caused it to break. If the bar is still straight, get it welded. The bar on my MF31 sicklebar that I bought at auction was so bent that it was useless. I got a piece of steel bar from my supplier and drilled holes for the sickle sections and the drive attachment. The cost was low and it just took me a few hours to do the drilling.
2005 Holiday Rambler Alumascape Travel Trailer (A48082)
2005 Holiday...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2013 Dodge Grand Caravan SXT Van (A48082)
2013 Dodge Grand...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
Shack (A50860)
Shack (A50860)
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
