In Need Of Advice
   / In Need Of Advice #1
EaTmYtAiLpIpEs
Can someone help me, give me advice, or give me plans, and pictures of stuff you have made for your 3 pt hitch. I want help on fork lift attachment for 3 pt hitch, back blade, and a platform.
   / In Need Of Advice #2
What size tractor and Cat. 3 PH? I made this for my Cat 0 3PH.
   / In Need Of Advice
I have a kubota b6000. How did you bend the blade? And where/how did you make the spindle the blade turns on. What type of steel did you use?
   / In Need Of Advice #4
I build a lot of the stuff I use on my tractors, and generally from whatever I have laying around. Here is a landscape rake, and a set of rear forks that I made. I didn't have any plans but I knew what they are supposed to look like .
HTH, Later, Nat
   / In Need Of Advice
HTH, Later, Nat
would you by any chance have pictures of the other side of the forks that everything hooks up to? What did you make the forks out of?what kind of steel?
   / In Need Of Advice #6
tailpipe, I had 2 pieces od 4" chanel iron about 32 " long that I made the uprights from and the bottom is a 32" piece of 5" chanel, top crossmember is the same. The forks are two pieces of 2x2x1/4 tubing. I cut 2 pieces of 2x2x1/4 angle 2" long and then hammered them closed till they were the same width as the tubing and welded them on to the end of the tubing so they wouldn't get packed with dirt. I made the uprights 26 " outside to outside and the bottom pins are 10 " up from the bottom and the top cross bar is 28" from the bottom. I then welded 2 pieces of 2x3/8 flatbar with a 3/4 hole in it for the top link.
I don't have any other pics now and it is raining, but will take some when it clears up. I'll also take some if my plow and disc incase they may help' later, Nat
   / In Need Of Advice
Ya thanks bud! I am gonna make a 6ft or 5 ft box blade for my 3 pt hitch. And I am also gonna make the forks and I am gonna make a dumping platform for the 3pt hitch too. But that is gonna take a lot of time so that will be last.
   / In Need Of Advice #8
You can get 3 point hitch dimensions from a ASAE site. Make sure you get the correct category!
   / In Need Of Advice
well I have about 10ft of angle iron i got from work. and at the best price to. free. I am gonna start the fab up a fork attachment today.
John Deere 460M (A57148)
John Deere 460M...
Hydraulic Breaker (A55973)
Hydraulic Breaker...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
utv cart Honda (A56857)
utv cart Honda...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
