In depth comparison of tractor vs. other machines. This is why tractors STILL rule
   / In depth comparison of tractor vs. other machines. This is why tractors STILL rule #1
kapper
Vienna, IL
Branson 7845C
Thanks for checking us out and if you enjoy our content please share our video to help us grow our channel. Thank you! Kapper Outdoors.
   / In depth comparison of tractor vs. other machines. This is why tractors STILL rule #2
Quote: "A backhoe lacks a PTO"
NOT TRUE!!!
Maybe check out Kubota TLB's: L35, L45, L47, L48, M59, M62
   / In depth comparison of tractor vs. other machines. This is why tractors STILL rule #3
NOT TRUE!!!
They’re not very good at 3 point pto work but the option does exist. Plus a mini and a skid steer doesn’t have a pto either.
yes, perhaps some of them do, none that I have seen. either way, I don't believe it would be the best fit for this Homesteader's first piece of equipment. Thanks for watching, appreciate it.
   / In depth comparison of tractor vs. other machines. This is why tractors STILL rule #5
The Kubota mini TLBs that Fred listed do. They offer a stronger loader vs a tractor and a better backhoe vs a tractor ( which significantly shortens the gap between a backhoe and a minix ). The Kubota TLBs are geared slow, non removable loader, and not a very efficient hydraulic pto, heavy, and only come with r4s, so they’re not the best tool for field work.
The Kubota mini TLBs that Fred listed do. They offer a stronger loader vs a tractor and a better backhoe vs a tractor ( which significantly shortens the gap between a backhoe and a minix ). The Kubota TLBs are geared slow, non removable loader, and not a very efficient hydraulic pto, heavy, and only come with r4s, so theyæ±*e not the best tool for field work.
Good info thank you. Also, I'd guess that they'd be pretty expensive as far as the budget goes? thanks
   / In depth comparison of tractor vs. other machines. This is why tractors STILL rule #7
Another consideration;tracked machines are "slow to move" and very expensive to repair.Tractor wins hands down for the average user.
   / In depth comparison of tractor vs. other machines. This is why tractors STILL rule #8
Not when the wheeled tractor is bogged down in the mud, and the tracked machine keeps on working.
   / In depth comparison of tractor vs. other machines. This is why tractors STILL rule #9
The tracked machines are the king in soft conditions and great for grading but the maintenance cost is high, the maximum travel speed is low, and the ground destruction is high. They’re not a good choice for a general maintenance machine IMO.
   / In depth comparison of tractor vs. other machines. This is why tractors STILL rule #10
Seems like it would be better if you posted your information here, in text rather than enticing people off site so you can earn clicks. Unless you're paying this site to advertise?
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
