In between the fender trailer with heavy axles
   / In between the fender trailer with heavy axles #1
bdog
Elite Member
Texas
John Deere 6130M
I am looking for a bumper pull or gooseneck equipment trailer where the deck sits in between the fenders and it has a low profile. Tilt would be preferred but dovetail and ramps would work. The kicker is I want it rated heavy. 10k tandem axles with 17.5" singles would be best but 8k might suffice. 7k ain't enough. Anyone know of a place that makes a trailer like this?
   / In between the fender trailer with heavy axles #2
IMG_1135.JPGAre you wanting 10K for each axle or 10K combined. I bought my trailer in Conroe, it has twin 6K dexter axles with electric brakes on each axle. Here is a photo of it with my LS P7010 loaded on it.
10k each axle. Either gooseneck or pintle hitch. I won't be loading 20k on the axles the load will be more like 15-16k on the axles depending on the weight of the trailer.
   / In between the fender trailer with heavy axles #4
PJ offers a 8k axle option for a bumper pull or gooseneck. After that you could always ask about custom.
   / In between the fender trailer with heavy axles #5
Does Big-Tex offer something that heavy? I have seen some heavy rated tralers of theirs in this area but never paid any attention to what they offer.
   / In between the fender trailer with heavy axles #6
With a 10K axle rating, would you be looking at something with semi-trailer tires (20" or larger) on it. I don't think you will find a 17" tire that will hold that much weight (5000 per tire).
17.5" Radial Tires
235/75/17.5 load range J are rated at 6,005 lbs a piece.
Lots of low profile step deck semi trailers have these tires on them instead of 22.5's. Four of them would be good for over 24k. Heck I could even go with 215/75/17.5 load range H at 4,805 lb a piece. That would give me 19,220 on the trailer. Not quite up to the axle rating but I don't plan on putting over 16k on the axles anyway.
   / In between the fender trailer with heavy axles #8
Most of these mfgs will build anything you want ..
   / In between the fender trailer with heavy axles #9
   / In between the fender trailer with heavy axles #10
Belshe trailers builds a lot of these for Vermeer and ditchwitch so you may want to check out those dealers.
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
