In-axle brake wires
   / In-axle brake wires #1
MillWeld
Durham NC
Ford 641
I'm still new to trailers and axles but here is a simple observation on the axles I have used (MH and commercial, AL-KO).
Axles that route the brake wires thru the tube have the access holes in the side of the tube. This allows rain and splash to get in and not get out. Why aren't the holes on the bottom so that the water drains out?:confused: I've routed conduit acound my trailer giving access to power on both ends of the axle, removed the in-tube wire and welded it closed.
Bob
   / In-axle brake wires #2
Bob
I put silcone around the holes on mind, or what ever you perfer, that would help.
   / In-axle brake wires #3
Not sure. I have personally only see one axle fail and it was a MH axle. I have seen burnt up spindles, bent spindles, ect but only one tube failure.
Chris
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
Cherokee camper trailer (A51694)
Cherokee camper...
Hydraulic 80mm Quick Coupler (A52384)
Hydraulic 80mm...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
