Improving PC Performance
/ Improving PC Performance #81
Glueguy, I use to have a packard bell(yes I said Packard bell/w3tcompact/icons/shocked.gif) with a .245MB hard drive and it was a seagate, When it got to full I put in a top of the line WD with a whole.845MB. Funny thing with that old packard bell is we never had any problems with it for 4years then we donated it to the salvation army, I use to also run a wildcat BBS on it/w3tcompact/icons/smile.gif
_______________________________________
Take care all, Jim
/ Improving PC Performance #82
Bird,
If you haven't already, go here: <A target="_blank" HREF=http://docs.us.dell.com/docs/systems/dsleest/syssetup.htm>dell site</A>. Scroll down to where it talks about Boot Sequence. You might be able to change the setting to A=floppy C=local D=CD and E=Zip Drive. If it already looks like that when you get there, then I would leave it alone. Be careful of any changes you make in setup. It is wise to write down any settings before making changes as you can always revert back. Hope this helps.
/ Improving PC Performance #83
Bob/Bird,
I have a Kodak DX3600 and installed the Kodak software directly onto XP. Not a problem. As far as Win2k, I would image that the software should be supported.
Bird, you gave the best suggestion in checking the Kodak website. The software enclosed may be older and not support Win2K.
Terry
/ Improving PC Performance #84
Bob,
Is it USB or parellel? Did you install the software on the CD before pugging in the camera? Did the camera cause the computer to reboot continually or did the software?
Bird,
I haven't forgot about your fax question. I could not find fxapi either and since I only own fax on W2K, my fax tester is following up with the XP fax guys in Hifia, ******. Might be a few days.
/ Improving PC Performance #85
Brandon, in surfing around on Microsoft's web sites, I found something (don't remember where now) that led me to believe that file may be included with XP Professional, but not the Home edition. At any rate, I got it working with Phone Tools. I appreciate your efforts.
/ Improving PC Performance #86
Instructions For Purchasing And Installing New Software
1. Examine the software packaging until you find a little printed box that explains what kind of computer system you need to run the software. It should look something like this:
SYSTEM REQUIREMENTS
286 PROCESSOR OR HIGHER
28.8 MEGAHERTZ MODEM
19.7 MB FREE DISK SPACE
546 MB RAM
32323 MB ROM
5948737 MB RPM
ANTILOCK BRAKING SYSTEM
2 TURTLE DOVES
NOTE: This software will not work on your computer.
2. Open the software packaging and remove the manual. This will contain detailed instructions on installing, operating, and trouble-shooting the software. Throw it away.
3. Find the actual software, which should be in the form of either a 3.5-inch floppy diskette or a CD-ROM, located inside a sealed envelope that says:
LICENSING AGREEMENT: By breaking this seal, the user hereinafter agrees to abide by all the terms and conditions of the following agreement that nobody ever reads, as well as the Geneva Convention and the U.N. Charter and the Secret Membership Oath of the Benevolent Protective Order of the Elks and such other terms and conditions, real and imaginary, as the Software Company shall deem necessary and appropriate, including the right to come to the user's home and examine the user's hard drive, as well as the user's underwear drawer if we feel like it, take it or leave it, until death do us part, one nation indivisible, by the dawn's early light,... finders keepers, losers weepers, thanks you've been a great crowd, and don't forget to tip your servers.
4. Hand the software to a child aged 3 through 12 and say, "(Name of child), please install this on my computer."
5. If you have no child age 3 through 12, insert the software in the appropriate drive, type "SETUP" and press the Enter key.
6. Turn the computer on, you idiot.
7. Once again type "SETUP" and press the Enter key.
8. You will hear grinding and whirring noises for a while, after which the following message should appear on your screen: The Installation Program will now examine your system to see what would be the best way to render it inoperable. Is it OK with you?
9. Choose one, and be honest:
YES
SURE
10. After you make your selection, you will hear grinding and whirring for a very long time while the installation program does who knows what in there. Some installation programs can actually alter molecular structures, so that when they're done, your computer has been transformed into an entirely new device, such as a food processor. At the very least, the installation program will create many new directories, sub-directories, sub- sub-directories, on your hard drive and fill them with thousands of mysterious files with names like "puree.exe," "fester.dat," and "doo.wha."
11. When the installation program is finished, your screen should display the following message: CONGRATULATIONS The installation program cannot think of anything else to do to your computer and has grown bored. You may now attempt to run your software.
12. If you experience any problems, electrical shocks, insomnia, shortness of breath, nasal discharge, or intestinal parasites, you should immediately say !$)$%@&*^)$*!#$_$*^&
13. At this point your computer system should become less functional than the federal government, refusing to respond even when struck with furniture.
14. Call the toll-free Technical Support Hotline number listed on the package and wait on the line for a representative, who will explain to you, in a clear, step-by-step manner, how to adopt a child aged 3 through 12.
/ Improving PC Performance #87
Just too accurate to be funny, MossRoad./w3tcompact/icons/laugh.gif/w3tcompact/icons/wink.gif
/ Improving PC Performance #88
Brandon:
It is connected to the USB port. The first time she tried to install it, the camera was plugged in and on. The "Found New Hardware" message came on the screen, and it proceeded to shut down and re-boot itself over and over again.
Bob
/ Improving PC Performance #89
/ Improving PC Performance #90
I'm sorry, that was not productive or helpful, but I couldn't resist. You don't know( well, you do now) how many times I have had to fight with a company to get the answers to their own products. I share your frustration and admire your stamina. I'll keep following this thread.
/ Improving PC Performance #91
Brandon, that link sure makes it look like you're right. I probably didn't even need to download BVRP's Phone Tools; however, I haven't tried the instructions in the link, since I at least have my fax working with Phone Tools now. Too bad Dell's support people didn't know about that link./w3tcompact/icons/frown.gif
I first thought I'd just leave it aone, since my fax works now, but then I decided I'd just have to try the directions in that link, since it says XP Home edition. Well, all that did was get me back to that same screen asking for that file from the CD that doesn't exist./w3tcompact/icons/frown.gif Reckon when Dell made their OEM modifications to XP, they deleted that file?
/ Improving PC Performance #92
Bird,
One of the things that irks me about "Support" people is that each one has a DIFFERENT answer to your problem. I have noticed this here at work and it makes me crazy. Some are wonderful and some are, well.......
I think that they are afraid to say, "I don't know the answer to your question." I is great when they do say that and say, "I will get back to you with an answer very soon!!"
Terry
/ Improving PC Performance #93
Yep, Terry, it would be nice if they'd just admit it when they don't know, and then try to find out, but a lot of folks just won't do that; they'd rather "pretend" to know when they don't.
/ Improving PC Performance #94
<A target="_blank" HREF=http://www.expertcity.com/c/corp/expertlive?SessionInfo=8224976/47564702BF94E4C/null>http://www.expertcity.com/c/corp/expertlive?SessionInfo=8224976/47564702BF94E4C/null</A>
Bird, the above site puts someone with a computer problem in touch with "experts" via the site. You describe your problem on a bulletin board and " experts" bid to correct it. Apparently there is a guarentee and payment is via credit card. It was favorably reviewed in the New York Times about 8-9 months ago. The site can enable the "expert" to view your screen as you see it. I have no personal experience. I'm lucky, I've got 14 & 18 y/o sons that have immersed themselves in bytes and binary and solve all my problems with computers.
A little later;
<font color=red> I see that the format has changed since 12-14-01 and the bidding business is different</font color=red>
/ Improving PC Performance #96
GlueGuy, Finally had the time to reformat and restore my cpu to original and that took care of all my problems. I also was going to just leave the win98 2nd edition but it would not reconize my linksys nic so I reinstalled me and it had no problem. I also was having problems with my cpu locking up on TBN after I installed our new dsl connection, but also a few other sites to, then it went to the blue screen of death from visiting TBN (cant be having that, its one of my 2 favorite sites /w3tcompact/icons/smile.gif ) That is when i took the time and hours to do the cpu, now with all that done i found out the new cpu has just been shipped. Thanks for all the help to everyone.
____________________________________________
Take care, Jim
/ Improving PC Performance #97
RickM
Thanks for the link. I'd been to the Olympus Website before and knew they had the software, but when it came time to actually download it, I couldn't remember where I had found it. Then I remembered this link. /w3tcompact/icons/smile.gif
This is the correct driver for Windows XP. It's marked as XP Home/Windows2000, but it's running on my XP Pro system without any problem. Now I just have to get my brain running on XP and everything will be ducky. /w3tcompact/icons/crazy.gif
SHF
/ Improving PC Performance #98
SHF,
I'm happy that link is still intact and the driver works for you. I think Bird said it worked for his upgrade to XP too. Cheers!
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
FERGUSON 21 (2) ROW PLANTER (A62130)
FERGUSON 21 (2)...
2018 Dodge 5500 Bucket Truck 4WD (A63118)
2018 Dodge 5500...
more info coming soon! (A61569)
more info coming...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
