Improved chute rotation mod for 59 snowblower and others.
   / Improved chute rotation mod for 59 snowblower and others. #1
larboc
hancock, MI
John Deere 4300, Deere 455, Ariens GT17, Cub Cadet O, Wheelhorse 50
I got tired of only having 180 degrees of chute travel so I bought an extra two pulleys and bushing and some wire rope. By adding two more pulleys to the center and anchoring the cable to the static shafts I get enough more rotation to just kiss the grill guard on my 4300 when fully lifted. Just used it for the first time tonight and it is MUCH better now in the wind and coming up to doors.
Figured I'd share in case others were interested. Should be possible on most Deere front blowers.
   / Improved chute rotation mod for 59 snowblower and others. #2
Good job. How are those winter tires working out on the front?
Thanks!
Working well so far, much better than the bald turfs that were on there before, appear to be the same size as the turfs were before they went bald as the turning radius that the 4wd lever falls in and out easily is just slightly tighter than the bald OE's. They hold up the loader weight about as well as the originals and grip better on snow, dirt, sand, and rocks. They plug up with dirt about the same as a turf. I have an old boxcar wheel on the back as ballast so I don't use 4wd that often, but when I do it's unstoppable. They do a better than expected job of steering because of all the radial edges too I believe.
The softer compound of a winter tire is better for traction year round, but I was worried about durability. I have had them about 2.5 years now and I have taken a couple of very small nicks out of the tread, maybe 1/8" wide piece off a corner here and there but that's it. They are Nokian Hakkapeliitta XL XL's, I forget the size. They were the highest load rating snow tire I could find that had the right OD, higher weight rating than the 6-ply OE Carlisle. So far durability has not been an issue and I've had them spinning in mud with sticks and rocks against the tread and sidewall. Sidewall strength was a concern when I was considering buying P-metric tires but I can cay that is a non-issue. They are very stable with a load in the loader.
Overall I see absolutely no reason to consider OE tires, except maybe for looks. I originally planned on grooving them to look more like a turf tire but lost interest and now the siping is full of sand so that will probably never happen.
O, and when I bought them it was the same price for 2 OE tires as 5 of these Nokians.
   / Improved chute rotation mod for 59 snowblower and others. #4
Nice job. I bet it is handy to use. It also reminded me of a thread years ago where someone did the same thing on a smaller Deere 2 stage blower. I wish I could remember more about it so I could find it and reference it here to inspire inquisitive minds. He had a truck load of pics and detailed instructions.
I meant to take more pics, but by the time I started doing it I was done!
Of the top of my head, you'll need
two of these: M85382
one of these: M85614
two grade 8 3/8" x 3" bolts
one grade 8 3/8" x 5" (might be +/-5") bolt
A bunch of 3/8" washers
two 5/8" nuts (I used them as clamps to hold the end of the cable, they slip over 3/8" nuts and then another 3/8" nut and washer forces them down to clamp the cable.)
I also have a piece of angle iron added across the top to help hold the pulleys from bending the bolts if the chute freezes.
So far so good, I've used it a few times now. The cable has loosened up a bit since initial installation, I'll need to tighten it up.
MAHINDRA 1635 TRACTOR (A57192)
MAHINDRA 1635...
UNUSED FUTURE 16" AUGER (A57193)
UNUSED FUTURE 16"...
Club Car Electric Cart (A55758)
Club Car Electric...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
2017 Chevrolet Tahoe (A56859)
2017 Chevrolet...
(4) BUNDLES (10) APPROX 16" ABRASIVE BLADES (A57192)
(4) BUNDLES (10)...
