Impossibly long thread about grease?
   / Impossibly long thread about grease? #1
hudr
Platinum Member
NE Texas
Mahindra 5005DI
It seems motor oil and to some extent hydraulic and transmission fluid have been uhhhh..... /forums/images/graemlins/smirk.gifdiscussed /forums/images/graemlins/smirk.gif.... to a point. But what about good ole grease? I seem to remember replacing more ball joints, wheel bearings, and pivot pins than engine kits in the past. What are y'all's thoughts on lowly grease? Has that industry kept up w/ the motor oil people in terms of improvements and specializations?
   / Impossibly long thread about grease? #2
"Has that industry kept up w/ the motor oil people in terms of improvements and specializations?"
AMSOIL has. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif May be some others. I wouldn't know since I only use Amsoil and that's for the last 16 years. /forums/images/graemlins/cool.gif No grease failures in that time frame and that's good enough for me. /forums/images/graemlins/grin.gif
   / Impossibly long thread about grease? #3
No. And it may not be possible. I think that the longer intervals between oil changes do not take into account greasing intervals, therefore as you said, worn out ball joints, etc. I spend a lot of time driving on gravel roads, so I try to throw a little grease in my vehicle in between oil changes. Now if I can get my wife to do the same.........
Interesting point on the extended drains affecting the application of grease. I fell under my recently purchased Explorer the other day for service. As the oil drips I normally hit the grease fittings. Guess what?! Not a fitting one on the front end of that Explorer. Nothing on the driveline either (I like greaseable U-joints). I wonder how many other vehicles out there are like that? No grease, just lots of rubber and poly bushings. I wonder what that will be like at repair time? I know great leaps and bounds have been made w/ sealed bearings, but I would still rather squirt a little grease in there from time to time.
   / Impossibly long thread about grease? #5
My 02 4X4 F250 only has 4 grease fittings, and they are on the steering linkage. With 7 u joints I know it's going to get expensive somewhere down the road.
   / Impossibly long thread about grease? #6
Use a good quality grease such as Mobil EP 2, or equivalent, Lithium base, some like the graphite additive, some like water resistance, especially in wet climates.
   / Impossibly long thread about grease? #7
With regard to Tractor Grease, I would buy two grease guns-why? Different Grease charicteristics. In areas such as Bucket pivot pins, steering linkages, anywhere two items rotate against each other I would use a Grease with a Molybdenum Disulfide additive. For all other places (wheel bearing,etc.-items that turn at a fast rate I would use a good high pressure Lithium Grease-
2018 John Deere 1653 (A55302)
2018 John Deere...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
2012 Cadillac SRX SUV (A53424)
2012 Cadillac SRX...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
2008 CHEVROLET C7500 BUCKET TRUCK (A51406)
2008 CHEVROLET...
