Important Hydro accessory *DELETED*
   / Important Hydro accessory *DELETED* #1
oldforestor
Golden Triangle KY
Kub M8560 Orange Millenium Falcon, Kub M4050 wonderful dependable relic
Post deleted by oldforestor
   / Important Hydro accessory *DELETED* #2
Re: Important Hydro accessory
The attachement didn't work. /forums/images/graemlins/frown.gif Is the file size under 100k?
darn! I had a great pic but it is too big. any ideas?
   / Important Hydro accessory *DELETED* #4
You could host the pic on a site other than TBN, like Webshots. I'm pretty sure they are free. You could resize the image. Depending on the format, you could change the type (.bmp to .jpg). I'm not sure what software you are using, so I can't effectively say how to resize the image. I use three different programs for images and each one is different in how to resize the image. /forums/images/graemlins/crazy.gif Changing file type is easy and pretty universal across programs. Click File, Save As. In the Save As window, click the down pointing arrow at the right of the Save As Type field (might be named something similar). There, you can choose what file type you want. It is best to save as jpg (jpeg) if the file is in another format. Bitmaps (.bmp) are generally rather large. Other file types may be larger than jpegs, too.
2008 Ford F-250 4x4 Reading Service Truck with Liftgate (A48081)
2008 Ford F-250...
2024 iDrive TDS-2010H Pro Jack M2 Electric Trailer Jack System (A49346)
2024 iDrive...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A48082)
2022 K-Z Sportsmen...
UNUSED 20 in. Gasoline Chain Saw (A50860)
UNUSED 20 in...
