Re: Important Hydro accessory
You could host the pic on a site other than TBN, like Webshots. I'm pretty sure they are free. You could resize the image. Depending on the format, you could change the type (.bmp to .jpg). I'm not sure what software you are using, so I can't effectively say how to resize the image. I use three different programs for images and each one is different in how to resize the image. /forums/images/graemlins/crazy.gif Changing file type is easy and pretty universal across programs. Click File, Save As. In the Save As window, click the down pointing arrow at the right of the Save As Type field (might be named something similar). There, you can choose what file type you want. It is best to save as jpg (jpeg) if the file is in another format. Bitmaps (.bmp) are generally rather large. Other file types may be larger than jpegs, too.
