Implent Tire Conversion Question?
/ Implent Tire Conversion Question?
This chart shows 5.00x15 size. Maybe work from that to find a close match.
Bruce
This helps too Thank You
You can buy a new 500-15 tire at Miller Tire for $88.00
Thank's I just ain't near miller tire, well bout an hour away, If i wanted Amazon will ship me 2 to my doorstep for rite around $170. Just looking to use what i have here maybe. Thank you for the reply though.
/ Implent Tire Conversion Question? #13
Yes i have the manuall tire changer and the black goo from napa, do my trailer tires when needed and a few front tractor tires when need arises (you know that need Saturday after lunch, everything closed got to get back to tractoring)I may check on the lube though, i been using the dish soap lube lol works ok. Thank You
I started messing with tires because of that time period between noon Saturday and Monday morning. I haven't been to a tire store in over 20 years. Even have a balancer but I hardly ever use it.
/ Implent Tire Conversion Question? #14
Hello I am trying to figure out what size tire I can Replace a set of 5.00 x 15 implement tires on my hay rake with. I was hoping to find or use some of the used tires i have around the farm i just do not know exactly what will cross onto the rims. I have tried online conversion charts but none of them list tires this size they only go down to about 7.00. Somebody had done this I am sure and can lead me to the right size. Thank You
PS if it helps the tires are going on a new idea 4150 rake 4 bolt rims
I am not specifically familiar with that particular rake but I strongly suspect it has 15x4 rims as that's the size Deere and New Holland used on their bar rakes with 15" tires. The 5.00-15 traction implement tires have a diameter of 25.6-25.8", which is very close in diameter to a 195/70R15, 205/70R15, or 215/65R15. 205/75R15s are about an inch larger. Note that those all used to be common sizes in the '80s and '90s, particularly the 205/75R15, but the only tires remotely close to that size currently used are ST205/75D15 or ST205/75R15 trailer tires, which are fine to use.
Do note that none are officially approved for a 4" wide rim, the 195s and 205s are generally approved for 5-6.5" rim widths and the 215s are for 6-7.5" rims. However, people put lots of 195, 205, and 215 section width take-off car tires on 4" wide rake rims and they have been running them that way for decades.
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
2011 Kubota KX080-3 Midi Excavator (A59228)
2011 Kubota...
Auger Drill Bit Skid Steer Attachment (A59228)
Auger Drill Bit...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
