Tires Implements Hitting Tires
   / Implements Hitting Tires #11
It sounds as if very little side-to-side movement of your implement will cause contact with your tire. So you must have little clearance between lower arm and tire. Your best (and most expensive) bet would probably be the "Ernie-type" bent lower arms that would give you more tolerance between arm and tire. As someone else mentioned, turning the pins inward, if possible, would also help.
   / Implements Hitting Tires #12
Is it possible that you are using the wrong implament for you tractor. I'm not sure if yours is a class one or a class two hitch. If you are using a class two implament on a class one 3 point hitch wouldnt it push the arms out closer to the wheels and couse this problem??.
Just my 2 cents worth.....
   / Implements Hitting Tires #13
What is the distance between your lower lift arms? Standard spacing is 26" for cat.1, which your tractor is, and hopefully, your implements. As others have said, you can reverse your wheels, reverse the pins to face in, use spacers on the lower pins to maintain a max of 26" on the lower arms. That should take all the side to side play out and they should not hit the tires.
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
1603 (A57192)
1603 (A57192)
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
2016 Chevrolet Van (A55973)
2016 Chevrolet Van...
2001 Nissan Pathfinder SE SUV (A55853)
2001 Nissan...
