Implements for MF 1010
   / Implements for MF 1010 #1
runner76
louisa, Va
Farmall M
I purchased a used MF 1010 tractor, 3sp hi and low range. 2wd. The tractor is in good shape and runs well. I had intended to get a 5ft finish mower to use it with, but got a 7ft bush hog brand turf hog finish mower for $125. That I am trying to get in shape now. I will be mowing yard grass on flat ground, will this tractor handle that big of a finish mower? I would also like to use the tractor to bush hog saplings and weeds along my fence row. Will it handle one of the Agri Supply 4 ft rotary (bush hog type) cutters? I know I should have asked these question before buying the tractor, but impulse got the best of this new hobby "farmer"
thanks, Frank
   / Implements for MF 1010 #2
I has to be the bearer of bad news, but I am not sure your tractor will even lift a 7' mower! My brother had a MF 1010, and it struggled sometimes with a 5' mower-if I recall those tractors had about 13PTO hp.
I did a lot of heavy mowing with a 4' bush hog with that tractor. It was slow at times but it worked. I think you'll be ok there.
Will
Well, it will lift the 7 ft. mower, be interesting to see if it will mow with it. The guy I bought it from was using (at least he had it attached) a 7 ft finish mower with it to mow his lawn, just what I want to do with it, and my ground is level. I am hoping if I down't let the grass get too high and keep the blades sharp, I can get by until I can sell it and replace with a smaller mower.
Good news on your experience with the 4ft bush hog. Thank you for the reply,
Frank
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A51039)
John Deere 6105E...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
