Implements for BX
   / Implements for BX #11
Re: 5 HP chipper?
Last one to the finish line, will probably convert it better.
Hope I can sleep to night. Dam chipper anyways.
   / Implements for BX
Well Darn, that is exactly what I want--that aerator from Ryan. How do these things discharge the plugs? Maybe I can build one--no actually I think I would rather buy one--have new airplane to build. J
   / Implements for BX #13
Millcreek has a line of core aerators that might work for you. Though I couldn't find it on their website, I'm fairly sure they have a lighter weight version (roughly, 4 feet wide, weight 150 lbs, cost $600). The professional models weigh about twice as much and cost at least 50% more. I'm definitely in the market for one of these, but they are awfully expensive.
Here's a link with pricing info on Kubota B series tractors.
   / Implements for BX #14
Re: discharging plugs
I'm not familiar with them - but I always thought the plugs get pushed out the top of the tube-things (spoons?). Sort of a continuous action - as each tube gets pushed into the ground the previous core pops out the top.
There - that's my engineer explanation for you!! /w3tcompact/icons/crazy.gif
I'm interested to know if that's the right answer!!
   / Implements for BX #15
Thanks for the post Will - I noticed that MillCreek has a 42" aerator listed on that page - is that the one you meant for $600?
They also have some information under 'Aerators' in their FAQ - have to scroll down the manure spreader stuff first.
   / Implements for BX #16
RPM,
The model 420 you see on their website, is in their heavy duty line. They also have an economy model, the 54-E, which costs about $600, but for some reason it doesn't show up on their website. I have their brochure which says that it is 54" in overall width, 51" coring width, 135lbs (for the 5 tine model). It looks like it is designed to have cinder blocks loaded on top of the unit for better soil penetration. Their number is 800-311-1323.
   / Implements for BX #17
I have been looking for a core aerators to fit my B7300 for a while that would also be reasonable. I found another source not mentioned here and that is from the folks at Trac Vac. I am not sure of the WEB address I think it is www.palmor.com. They have a light weight version that might do the job (they have 2 models 352 (32") and 358 (48") that you might want to check out.
   / Implements for BX #18
HAVE MILCREEK AERATOR, WORKS VERY GOOD. I USE 4 - 50 POUND SAND BAGS FOR WEIGHT. BOUGHT MINE AT AN AUCTION FOR $125.00, VERY GOOD PRICE I THINK. HAVE A BX2200, THREE POINT WOULD NOT GO DOWN LOW ENOUGH FOR AERATOR TO DIG INTO SOIL FULLY. DRILLED TWO MORE HOLES IN LOWER THREE POINT ARMS. BEHIND HOLE THAT WAS ALREADY THERE THIS ALLOWED LOWER ARMS TO DROP FARTHER DOWN.
   / Implements for BX #19
rwdunky
Can you give us a picture of that mod?
Winnipeg, Manitoba
2001 BX2200 All Kubota FEL, Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
   / Implements for BX #20
woodstock
Do not have equipment to post picture. I will get measurments and post them on monday. No computer at home only at work, don"t tell the boss.
2012 Ford F-250 (A55973)
2012 Ford F-250...
toro reel master (A56857)
toro reel master...
2014 International Derrick Digger Truck (A55973)
2014 International...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56435)
2016 KBH...
2012 PETERBILT 388 (A58214)
2012 PETERBILT 388...
