Implement Shed Build + PICS!
   / Implement Shed Build + PICS! #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
I recently completed a shed build specifically for my tractor and its implements. Here is a description and some recent pics.
I just completed a implement shed with covered 'lean to'/overhang on the non-weather side. I have a LOT of implements and wanted to be able to drive in on one end and access implements from either end as needed.
I built 9' high overhead door openings, by 10' wide for possible future tractor upgrade, with 12' wide shed dimension, and same dimension for the lean to portion. The header is at 10' high over the gable ends, with a peaked roof with ridge vent, asphalt shingles, and Red Hardie board smooth finish with white PVC trim and corner boards.
On the far gable end I added a 6 x 6" PT post that extends out over the ground by about 6' in length to use as a point to hoist whatever I might want to lift off the grade. I can drill a hole in the horizontal post and add a chain hoist, or just throw a chain/rope over the post to haul items I might want suspended for inspection/repair/painting as needed. See pics below for view of this add.
The project was NOT cheap, but looks great, and does everything I could possibly want it to. I added a man door for entry on the non-weather side under the overhang, and even with 12' overall corner to corner exterior corner board width there is just enough room to move around inside with the tractor/FEL and backhoe ON! The building is 24' deep, and just fits the tractor/FEL/hoe. I did not plan to store the tractor in the shed, but I can if needed, but it's tight. I have to turn the hoe to one side to get it all in if needed.
Building it a couple of feet longer would have worked, but at more expense, and as my builder said, the 12' wide by 24' long and 10' beam height had some arithmetic advantages for cutting plywood, materials usage without waste, etc.
There is a upstairs loft area, accessible via a hole in the loft floor, and the overhang area provides more loft storage as needed.
I poured a Alaskan slab of concrete and rebar reinforcement, with floor drain for snow shed and water. Ran electric and Cat 5E out to it, and inexpensive Andersen insulated windows. One overhead door has an opener, the other could have at later date.
I sunk down 4' precast post piers, and set pinned 6 x 6" PT posts for the lean to/overhand roof beam to set on. The front gable end has two 5' high x 5 foot wide outswing 'barn' doors for additional access to the loft area.
https://scontent-mia1-2.xx.fbcdn.ne...=1c549395dfd21ede5c905cd3fb33d8ab&oe=598D4372
https://scontent-mia1-2.xx.fbcdn.ne...=32c3c82519664ac01879a2c83bd2804e&oe=5982E6D8
https://scontent-mia1-2.xx.fbcdn.ne...=2b4ef0de7efb8f65912b266f7b3cb479&oe=598011EA
https://scontent-mia1-2.xx.fbcdn.ne...=65654ac6829a693068e18d019357fc9a&oe=5982E28A
https://scontent-mia1-2.xx.fbcdn.ne...=5d9e3aa6e061e69293d24d66652a9cfc&oe=599181C7
Above are pics of the nearly completed shed. It really rocks. Part of the added costs was I set it in a location where I needed to bring in a LOT of fill to get the land up to grade. Had I set it elsewhere it would have cost much less in excavation and site prep costs. But this is where it works best in conjunction with other buildings I have on premises.
Enjoy.:thumbsup:
   / Implement Shed Build + PICS! #2
Beautiful building. What's an Alaska slab?
   / Implement Shed Build + PICS! #3
Links are dead for me.
   / Implement Shed Build + PICS! #6
Me three
   / Implement Shed Build + PICS! #7
Me three
I take it you were able to see the pics? Some are say the links were dead?
Alaskan slab: REVISED description: See what TCJatco stated on page 3, post # 26 of this thread, for a more accurate description.... to my understanding, the excavation was footers down to a couple of feet, then a 4" ? 6" FLOATING slab, reinforced with rebar, and tied together, and the apron at close end also rebarred to the slab, but poured a different day to allow for separation/slope for water, etc.
Also refer to post #29 where a detailed description is given in the link supplied.
At least that's what my builder calls them?:confused3:
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2001 HEIL PNEUMATIC CEMENT TRAILER (A51222)
2001 HEIL...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
