Implement falling off SSQA
   / Implement falling off SSQA #1
6sunset6
Veteran Member
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
My tractor NH TC34DA is 10 years old . It was new and came with a NH SSQA. The last couple of years when I roll the bucket all the way forward it fell off sometimes. I roll it that way because I have a grab arm that closes over the bucket. If I want to grab something big I have to roll the bucket so the grab arm closes around the object against the bucket. I though the pins on the SSQA were getting worn so I added some material by welding. Did not seem to help much. Anybody else have this problem? I could buy new pins they are around $40 each. But if it does not fix it I will not be happy. I never liked that SSQA . I like the ATI ones . I had one of those on another tractor. Any thoughts ?
   / Implement falling off SSQA #2
How tight of fit are the pins fitting in the bucket.
To tight the pins can't go down all the way, to loose and the pins can be pushed up/out.
If set/working correctly the bucket on a SSQA will not come off.
thanks read thru the whole thing. I was thinking of new pins. I think they could be an inch longer and still lift clear.
I got new pins new PN replaced old no. An inch longer . I would guess I was not the only one with the problem.
2015 KENWORTH T680 (INOPERABLE) (A52472)
2015 KENWORTH T680...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
