implement-ation misuse = abuse?
   / implement-ation misuse = abuse? #11
ok, how about implementing your consideration, i may not be the sharpest tool in the shed, but with determination, i'll get the job done. that's why i appreciate the opportunity to be able to ask and learn. with all the information that is offered throughout this discussion board, even the dumbest question can be answered with knowledge from those that range from experts to wanna-be's. those that have something to offer are understanding with those that desire to learn, please don't make a mockery of my effort to become better farmer.
   / implement-ation misuse = abuse? #12
I do not understand your post. Was something deleted?
Why do you think someone is making a mockery of your effort? What effort?
   / implement-ation misuse = abuse? #13
Huh??? Not sure what you are referring to here and the lack of information in your profile makes it difficult to add further comment
No ... wait a minute ... is that sarcasm I see?? /forums/images/graemlins/grin.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
Bob
   / implement-ation misuse = abuse? #14
Just bolted a used 1/2 inch thick plow point to the outside end plate of my box blade and then used it to slice 3 inches deep into the turf---perfect to install low voltage walk light wires--When the wire is pushed down in the slot, I just drive my Kioti LB1914 tires over the slot and it closes right back up----My wife just hates it when I figure easy ways of doing her honey do projects.--Ken Sweet
Sweet Farm Equipment Co. *Hay Specialists*
   / implement-ation misuse = abuse? #15
Took the bucket off my old 3550 Ford hoe and mounted a boome i built on it to put in bridge timbers. TOday used the bushog on the 4000 FOrd ate woth to box blade because the tight wads want to get 3 estimates on a fuel pump repair for the dozer. Bolted a disc breaker on the tip of a King Kutter angle blade yo clean out ditches. mount a forklift mast to the t3 point of a tractor with a hydraulic gear motot and combine auger to drill a small water well 70 feet deep. One job as an operator i mad a 2 inch plate of steel with a sleave to slide on the 5000 pound hammer on my 300 komatsu i ran to compact backfill and trenches.
   / implement-ation misuse = abuse? #16
</font><font color="blue" class="small">( My wife just hates it when I figure easy ways of doing her honey do projects. )</font>
I bet it really makes her mad when you do them on the tractor! /forums/images/graemlins/grin.gif
   / implement-ation misuse = abuse? #17
Hello--You are right, she does seem to find a couple more to do when I finish early and easy--The joke is actually on her--Because I really do enjoy this kinda stuff anyway--I have just about got her convinced that I need a good used backhoe to put in the new pool, so we can save a lot of money!!--I think she is going for it?--Ken Sweet
Sweet Farm Equipment Co *Since 1977*
   / implement-ation misuse = abuse? #18
</font><font color="blue" class="small">( <font color="blue"> How about using a FEL to mix up a small batch of 'crete? </font> )</font>
You are working on the wrong end of your tractor Sendero. You start by putting a barrel on the ground and then back your tractor up to the barrel with the post-hole auger attached. Lower the auger into the barrel and then fill in around it with concrete mix and water. Slightly raise the auger with the 3PH and then slowly engage the PTO. You'll have that concrete mixed in a flash and when you are finished, dump the barrel into your FEL and carry the concrete to where you need it. Each barrel will hold almost 1/3 cubic yard of concrete, so you can get a cubic yard in only three loads... and... and... Uhhhh, /forums/images/graemlins/tongue.gif, I hope you realize this is completely tongue-in-cheek since you did specify a "semi-serious" thread. /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
There are so many good ways of mixing concrete that won't get you hurt, cost more than having it delivered, or make you the butt of family jokes for years and years. I have a small concrete mixer that I can use to mix concrete where I have electricity and then haul it with my tractor to a location where I need the "mud" to do a job. That's about as far as I'd go with using my tractor to do concrete work. ...but hey! I'd pay money to watch someone try the auger-in-a-barrel method. /forums/images/graemlins/laugh.gif
On the completely serious side of this discussion, one thing I've found to be easy and that I learned here on TBN is using the FEL bucket to shove T-posts into the ground. If you don't hit a rock, it works great and two people can set a bunch of T-posts in a short period of time. At the opposite end of the fencing job, I recently used my FEL to pull about a dozen crosstie posts out of the ground (3-1/2' deep) and snatch t-posts up like pulling toothpicks. I'm sure the FEL wasn't designed for this, but I can't think of any easier way to do the job. /forums/images/graemlins/cool.gif
   / implement-ation misuse = abuse? #19
I have used a york rake to remove snow before. /forums/images/graemlins/smile.gif
Knowles
   / implement-ation misuse = abuse? #20
Sometimes I drive my tractor to the mailbox when I don't feel like walking. /forums/images/graemlins/grin.gif
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
UNUSED FUTURE (100) PIECES OF 12'X3' GALVALUME (A57193)
UNUSED FUTURE...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A57024)
Midwestern...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2018 International Durastar 4300 Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A55852)
2018 International...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
