Impeller removal from Meter snow blower
   / Impeller removal from Meter snow blower #1
Farmer Rob
Massey 4707
Does anyone know how to remove the impeller from a meter snow blower?It looks like a bolt with lock washer but not sure once that is out then how to remove the impeller
   / Impeller removal from Meter snow blower #2
In theory you slide it off the shaft. In practice you will probably cut it to pieces with a torch. If you are lucky you will fabricate a means to attach a puller to it and force it off without inflicting damage to the impeller or the tapped hole in the end of the shaft. You will find the impeller keyed to the shaft.
   / Impeller removal from Meter snow blower #3
If you look close the impeller opening may not be as big as the impeller..thus you cant just pull it streight out/off the gear box. You may have to remove the gear box first then tip it out the front.
   / Impeller removal from Meter snow blower #4
Good point.
CAT Skid Steer (A50322)
CAT Skid Steer...
2002 LEEBOY L7000T ASPHALT PAVER (A52705)
2002 LEEBOY L7000T...
KUOBTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUOBTA M6800...
ASSET DESCRIPTIONS & CONDITION (A54607)
ASSET DESCRIPTIONS...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
