iMatch vs Speeco / FarmForce Quick Hitch: Experiences and Opinions?
   / iMatch vs Speeco / FarmForce Quick Hitch: Experiences and Opinions? #21
Semipro,
I think you have the right idea with the 15" vertical spacing, just make sure you have room for the hook to clear from the bottom while hooking up. Same thing goes for the lower links
These quick hitches have been around a long time, sure wish I had done this 30 years ago for my dad.
   / iMatch vs Speeco / FarmForce Quick Hitch: Experiences and Opinions? #22
   / iMatch vs Speeco / FarmForce Quick Hitch: Experiences and Opinions? #23
Here are the ASAE Specs:
LSU
Imatch
Yeah, these are the specs that made me think I should modify my implement(s) for 15" of vertical spacing. I just wanted to make sure I wasn't missing anything. I know also I'd rather not have to adjust the top hook on the Speeco for different implements. Future implements will either have to adhere to this standard or be modified to to work.
Thanks for the replies.
   / iMatch vs Speeco / FarmForce Quick Hitch: Experiences and Opinions? #24
You are on the right track. Once you've picked a spacing, EVERY new implement will need some modification. They all vary a bit. If you had three or four already, you could measure them all and maybe find two that are close to the same, then use that spacing as your new "standard". If you have only one, 15" is a good number to use, and later the new implements will be able to conform to that (most with slight modification).
2003 Sea Ray SLX 29' (A56859)
2003 Sea Ray SLX...
1667 (A57192)
1667 (A57192)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
