IMatch question
/ IMatch question #1
KB9UDE
Platinum Member
North of Tower Hill, IL
John Deere 4066r John Deere 2025r
Has anyone here made a Bush Hog RDTH84 finish mower quick hitch compatible??
John
/ IMatch question
Does anyone know how I can make the RDTH84 IMatch compatible??
Is this too much mower for a JD 3320??
If it is I can always use the 5203.:D
John
/ IMatch question #3
John,
Do a search here for "floating top link".
It should be no problem. I experienced the same situation with my Woods RD72, and purchased a Speeco top link from TSC based on input from fellow TBNers.
What it does is provide a hinge joint at the top link so that the mower can flex over the terrain.
I don't know, however, if your lower pin widths are made to QH specs.
Bush hog lists a 30hp+ spec for this mower. The 3320 is around 25hp.
Jon
/ IMatch question
The lower pins line up perfectly. I need a floating top link as you mentioned.
/ IMatch question #5
galwayboy: Any chance you still have the TSC item number for the floating top link?
Case CX75C (A62177)
Case CX75C (A62177)
2017 Mack Semi (A64047)
2017 Mack Semi...
UNUSED WOLVERINE PT-16-01C 3 PT QUICK TACH (A64281)
UNUSED WOLVERINE...
(2) ROOKIE SHEET RACKS W/WHEELS (A64281)
(2) ROOKIE SHEET...
2019 Ford Transit 250 Cargo Van (A61573)
2019 Ford Transit...
Crate of Misc Parts (A64119)
Crate of Misc...
