IMatch question
   / IMatch question #1
KB9UDE
Platinum Member
North of Tower Hill, IL
John Deere 4066r John Deere 2025r
Has anyone here made a Bush Hog RDTH84 finish mower quick hitch compatible??
John
   / IMatch question
Does anyone know how I can make the RDTH84 IMatch compatible??
Is this too much mower for a JD 3320??
If it is I can always use the 5203.:D
John
   / IMatch question #3
John,
Do a search here for "floating top link".
It should be no problem. I experienced the same situation with my Woods RD72, and purchased a Speeco top link from TSC based on input from fellow TBNers.
What it does is provide a hinge joint at the top link so that the mower can flex over the terrain.
I don't know, however, if your lower pin widths are made to QH specs.
Bush hog lists a 30hp+ spec for this mower. The 3320 is around 25hp.
Jon
   / IMatch question
The lower pins line up perfectly. I need a floating top link as you mentioned.
   / IMatch question #5
galwayboy: Any chance you still have the TSC item number for the floating top link?
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
2020 Crane Carrier Co Side Loader Garbage Truck (A48081)
2020 Crane Carrier...
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A48081)
2015 Chevrolet...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
