Imatch question/help
/ Imatch question/help #1
19977
Smyrna,Delaware
JD 4520
I just got the Imatch set up and hooked up my 674 rotor tiller and one side of the Imatch lower link won't lock. And the top link won't go all the way down on the Imatch , it barely catches. I have the 4520
Mike
/ Imatch question/help #3
Mike,
A whole array of questions come to mind. Do you have a way to post some pic.'s? Without seeing it 1st hand, there could be a lot of useless speculation.
Is this CAT-1? Then, the first, and most basic question; Is the 674 Rototiller spec.'ed to be I-Match compatible (i.e. 26" minimum between lower lift hooks and 16" vertically from there to upper lift hook)? My I-Match is actually 27 1/2" C/L to C/L between lower lift hooks and 15 1/2 from there, vertically to the C/L of the upper lift hook. It works great on my "I-Match Compatible" RB but, I'm not having as much luck making it work with my 1060 GM with the "I-Match Compatible Conversion Kit".
Tom
My tractor is a CAT.1,and the tiller is set up for Imatch.I used the bushings that came with the tiller.I'm going into town a little later and see if they have anything on the lot thats already set up.I tried posting pictures before but it was to big to post.
Thanks Mike
/ Imatch question/help #5
Mike,
Please post what you find out. I'm not sure but I am beginning to think that all "I-Match" compatible (w/o need of a conversion kit) may not be all that compatible without more than a little re-adjusting of all lift and link arms. If that is the case, what's the point. As I said, the RB works great on the I-Match. If all worked that well I'd be in heaven.
Tom
/ Imatch question/help #6
Some times the top link lenght needs to be adjusted to get things to fall in right. I've picked up my rear blade and had it hang up till I adjusted the toplink.
You may try fitting the Imatch to the tiller while it is free (get a helper they are heavy and awkward) from the tractor to verify fit.
KennedyD, i know what your saying.I turned it in & out ,still with no luck.Istopped by the dealer & he didn't have anything set up with the Imatch,they'll be coming out Wed. with my new PTO shaft,and we'll see if they can figure it out.The only thing that i see that might be wrong ,is the two lift link connections on the tiller my not be installed correctly,as in they may be upside down.
Thanks Mike
/ Imatch question/help #8
You make some good points. Once the attachment is 'made' to fit, then its good to go.
I'm 'in heaven' with my i-Match, but the attachment has to be of the right 'persuasion' for the fit. The 3 i-Match points are fixed, and only if the attachment mates with those three points, can one expect the quick attach feature to work right.
No miracles, or 'close enough' will do. No rocket science here. /forums/images/graemlins/grin.gif My attachments all fit, now that I have applied some 'persuasion' (trip to the welder for cutting torch and re-weld instead of a 'kit') of my own to make them fit. /forums/images/graemlins/grin.gif
Well,after i got up this afternoon i went back to the shed and took another look @ the Imatch.With nothing to lose,i decided to reverse the lift hitch brackets on the tiller.Well,that was the problem all along,everything fits perfect.The dealer still has to bring out the PTO shaft tomorrow,then were all ready to get dirty,if it doesn't rain all this weekend.I got to tell you that the dealer ( shop )here town has really been decent with me and patient.
Thanks for all the replys
Mike
/ Imatch question/help #10
Good to hear that is solved. Have fun. /forums/images/graemlins/wink.gif
/ Imatch question/help #11
<font color="blue"></font><font color="blue" class="small">( The dealer still has to bring out the PTO shaft tomorrow,then were all ready to get dirty,... </font>
Mike,
Glad it's fixed! Hope they get you the shaft soon.
I talked to my dealer today about the GM shaft extending so far after adding the "I-Match" conversion kit. He FREAKED. He couldn't believe there was no warning that a longer shaft would have to be used and that the shields were leaving 1 - 2" of exposed shaft now. He said they'd "fix it or replace it" for free. Nice to have a good dealer.
2006 JOHN DEERE 444J WHEEL LOADER (A67714)
2006 JOHN DEERE...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2015 PETERBILT 389 T/A 6X4 SLEEPER TRUCK TRACTOR (A69167)
2015 PETERBILT 389...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
