iMatch or other 3PH Assist...
   / iMatch or other 3PH Assist... #11
I got Pat's. I didn't want to have to buy something for every implement. I also did not want to have to stick to compatible implements since they are usually not the cheapest and that would mean even more cost in the long run. I also use a PHD.
Pat's is great, it makes it easy to hook up the draft links to heavy implements I probably couldn't hook up otherwise. That is the hard part IMO.
   / iMatch or other 3PH Assist... #12
Here's what you do. You use Pat's system, then hang a I-Match on that, then hang the Speedco version on that when the toplink is in the wrong place! What could be simpler?
Cliff
   / iMatch or other 3PH Assist... #13
If I was in the market for a quick hitch system, I think I'd go the Pat's system. That way it'll fit anything you have now and your choices will be better for future purchases. The only thing is you have to attach the top link yourself but that's no biggie.
As far as ballast goes, and if you have a need for one, get yourself a good heavy box blade. A dual purpose implement is money saved.
Myself, I use the telescoping draft links and they work great but they're not for everyone.
   / iMatch or other 3PH Assist... #14
The I-Match will work great with the tnt system.
   / iMatch or other 3PH Assist... #15
I use the I-Match. I did some mods to some of my other implements. I have a torch and welder, so it wasn't a big deal to me. The quick hitch, which ever one you decide, is a big improvement over wrestling implements!!
I love the iMatch - definitely worth the $$$!!!
Talk about easy. I'm sure that I should have gone without it for a while so I could REALLY appreciate what it does, but I'm not as young as I used to be...
   / iMatch or other 3PH Assist... #17
Mike: Make sure the dealer gives you the pins that will cover your implement pins and fit into the space on the quik hitch.
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
HUSQVARNA RIDING...
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
Towable arrow board (A55973)
Towable arrow...
