Mowing iMatch and MX5 mower?
   / iMatch and MX5 mower? #11
Basically, you need a total of 6 bushings in order to "modify" your standard implement to a iMatch implement. The quick disconnect is a Cat 3 bushing size, as far as I know, there are no Cat 1 to Cat 3 bushings, so you must go in steps from Cat 1 -> Cat 2, then from Cat 2 -> Cat 3. The bushings for the toplink are a smaller diameter than the bottom link. So you need 4 bushings for the bottom link (2 ea. Cat 1-> Cat2, 2 ea, Cat 2-> Cat 3) and 2 bushings for the top link (1 ea Toplink Cat 1-> Cat2 and 1 ea. Toplink Cat 2-> Cat 3).
Here is where the differences come to play. With standard bushings you have to use a pin to hold the whole thing together, with the JD set you have a shoulder that helps guide the hitch onto the implement. I have tried both ways and prefer the JD bushings (iMatch Kit) as I have bent one of the end pins when just using bushings.
Hope that helps.
Derek
(10) 12" X 22# I BEAM (A57192)
(10) 12" X 22# I...
UNUSED FUTURE (3) AUGER SET (A57193)
UNUSED FUTURE (3)...
(APPROX 16) 6" UP TO 20' CHANNEL IRON (A57192)
(APPROX 16) 6" UP...
John Deere Hopper Assembly Kit Parts (A56469)
John Deere Hopper...
2018 Ford F550 Chassis (A55973)
2018 Ford F550...
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
