I'm trying to decide what to do my my backup saw.
   / I'm trying to decide what to do my my backup saw. #11
Worth rebuilding for sure. I owned a ported 357 and this stock muffler modded 361. Things I like about each one and things I disliked. Wish I could have combined the 2 likes.
Back in the day (when I was much younger) I raced 2 stroke motorcycles. Hare scrambles, not motocross. Each winter I would put my CR250 in the basement and tare it apart. Over the years I've had several cylinders replated. I don't think you could port a dirt bike cylinder since they have mechanical valves to adjust the exhaust port. Depending on the design some would need the carbon removed often or they would gum up or build up and when the valve closed the carbon would rub on the piston. I've never had the need to port a 2-stroke cylinder (I have ported and polished intake manifolds on car engines) so I never had any experiences with longevity. I actually debated having my cylinder ported but the saw has lots of hours on it so I wasn't sure pushing it further was going to be a good idea. If I replace the crankshaft, main bearings, and seals I still might do it. But since it's going to be a limbing, small tree saw it really doesn't need more power. Still I would like to learn about porting.
   / I'm trying to decide what to do my my backup saw. #13
I dont have anything ported anymore. Just not needed IMO.
Cutting the wood it never notices anyways. Who cares if it takes 10 seconds or 14 seconds per cut.
   / I'm trying to decide what to do my my backup saw. #14
I had a motocross bike 30+ years ago, too. Just for screwing around on. First year water-cooled 81 Yam YZ125. Long
gone.
Now, I have a more modern, but vintage mid-90s Suzy RM125 racing kart, and it has the exhaust power valve.
The racers tell me they go as rich as 33:1 on the premix, even when they use exotic full-synthetic oil. They
DO gum up the exhaust, but rebuild every 40hr or so. Not me: 50:1, but soon, full-synth oil.
Anyway on chainsaws, I often see the exhaust port not very well-matched to the gasket, and that's an
easy fix. Gaskets are not really necessary anyway. What folks need to know is that you have to
periodically clean the exh ports of carbon deposits, which get sucked into the cylinder and scratch it.
Tossing the spark-arrestor also helps breathing.
You are not doing any 2-stroke favors by running richer than 50:1 as it increases deposits. 50:1
oils (JASO-FD) work very well on older saws, too.
I had a neighbor that had a Mccolloch Eager Beaver chiansaw that he would run at 16:1. If it was a nice still day all you could see was exhaust smoke. He was always going through plugs and the muffler looked like the Exxon Valdez. But he swore that was better than running at the recommended 32:1. I usually run around 40:1 but I keep an eye on the plug and muffler. Oil is cheap so I don't mind burning a little extra. I think it's an old habit (kind of like my old neighbor) from the Lawnboy days. They were probably the best push mower ever made yet I lost count of how many were killed by running straight gas. I like to see the gas visibly different in color to know that it's not straight gas.
   / I'm trying to decide what to do my my backup saw. #16
I run 32:1 and will not go any further then 40:1. Replaced to many crankshafts (due to big end bearing wiped) and crank bearings run at 50:1.
Heck the racesaws were run 20:1 to 24:1.
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2154 (A58376)
2154 (A58376)
Ford 8340 (A53317)
Ford 8340 (A53317)
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
HELI 5K FORKLIFT (A58216)
HELI 5K FORKLIFT...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
