I'm slowly learning. (long story)
   / I'm slowly learning. (long story) #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I'm slowly learning what most of you already know. But, it is through trial and error. Mostly error.
This weekend I went down to my place to prepare my little food plots for the fall. I plant oats and I use my boxblade to scratch up the ground and then a homemade harrow to cover it all up. I've done this about two years in a row. The plots are small (no more than 1/4 acre) and the soil is awful ranging from dense clay to sandy clay with rocks. But, with the right amount of lime and fertilizer the oats do okay.
The problem this weekend is that since I've been fertilizing these plots for two years they had a pretty dense covering of fescue and weeds. More than ever before. In the past it has just been dirt and a few scruffy weeds. The boxblade was fine for roughing up the dirt. But, it was terrible with all that grass and junk, even though I had mowed it very close. It clogs the boxblade teeth and it won't dig. After an hour of thrashing around in it I realized I had a big problem. I could scrape all the grass away but it would take the topsoil with it. I had a real mess.
So I stopped and stood in the shade and pondered and it occured to me that I needed something that would turn that turf over. That's when the light went on. So that's what a plow is for!! But then I thought about what you'd do next. It would all be turned over but still in big clumps. Then the next light went on. A disk would do a good job with that! And of course after trying to push a yard fertilizer spreader around in that rough stuff it also occured to me that a tractor mounted spreader sure would be nice.
That night at supper I was lamenting to my B-I-L (who is a rancher) how I'd suddenly discovered the tools I needed but that they'd cost around $2000 which I don't have. Then he tells me he has a plow I can use. I didn't get real excited because usually when he says something like this I find whatever object he is referring to half buried and more rust than metal.
The next day as we were feeding and moving cows he points to a big pile of rusty junk and says the plow is in there. Well, after digging through briars, sheet metal, barbed wire and pickup truck rear ends I find it. It isn't a plow at all but it is a largish middle buster. It is a rusty, homemade looking piece of junk that looks like it has been repaired half a dozen times. One of the hitch pins is bent into an 'L' shape and the top link bracket is splayed apart.
I pulled it out and asked him if I could fix it and give it a try, warning him that I was sure to break it again. After a lot of WD-40 I got the rusty hitch pin out and put a new one on it. I banged the top link attachment closer together with a sledge hammer and presto, I've got this:
Well, in a nutshell it worked like a charm. It took me a few passes to get the angle right and a few more passes to get the speed right, but I was amazed how well it works. I did hit some dense, rocky hardpan about 5 inched deep that it would not cut through, but everywhere else it was fine. In 4wd and 3-lo I had the speed right. Turned the sod right over. It caught on a few rocks and actually pulled a small lighter knot right out of the ground but the tractor kept going and nothing broke. I set the 3 pt hitch with a little side to side play.
Not having a disk yet, I broadcast the oats and dragged over them with a homemade harrow. Not ideal, but a step in the right direction.
So next year I should have this down. I'll turn everything over a few times with the free middle buster (a real plow might be better, but free is free) a few weeks ahead of time. Then I'll disk (I hope to have one by then). I also hope to have a spreader by then too.
Live and learn.
   / I'm slowly learning. (long story) #2
I went through similar development. I purchased the midbuster for ditching and found out it is not the way for virginia clay and rocks.
But I use it to turn dirt over, we dump horse manure to one half of the garden - the second is planted - and i run the buster there every week or so to make sure it does not overgrow with weeds and to help the poop to turn in dirt.
   / I'm slowly learning. (long story) #3
Two weeks ago I decided to enlarge one of my small food plots. Sprayed the spot with Killzall (generic roundup) with a 2 gal. hand held sprayer. It did the job. Made a few passes with the disc and it is ready to plant. Just waiting on some rain . First time I ever used a herbicide. Since then, I have already sprayed another 1/2 acre.
Maybe I should add a sprayer to my list!
   / I'm slowly learning. (long story) #5
This is what I use to bust up & ready food plots. I use it in the order pictured...the BB ripper teeth take the most abuse. I have a harrow but I've never used it. I'd love to have a middle buster for ditching and trenching, but I make do. I think the "lightbulb" goes on for everyone when we realize what a specific tool is used for...then we simply must have one! Its a vicious cycle...
btw, the adult beverages in the cooler are a mandatory/non-negotible must have tool. They grease the other tools up and get em' ready to work.
I've thought about a tiller, but I've got more rocks than dirt. I'm afraid I'd kill a tiller. I think turning things over with the middle buster and then disking will probably do the trick. I'll let you know next year...at which time another light bulb may go on!
   / I'm slowly learning. (long story) #7
You can also start thinking about a spring tooth harrow.
SInce you have about 6 months, why not start going to farm / equipment auctions? You should be able to get an 8-10 foot disc for a couple to few hundred and a spring tooth for about the same. If you can find a 2 bottom plow that would be better than the middle buster.
jb
on edit...
Oh, forgot to mention. I also plant field peas, canola and buckwheat, spring wheat along with oats/clover blend. (You are planting clover with the oats, right??) The buckwheat comes up FAST and the deer up here just munch it down. Plant in strips to give a smorgasborg of green growing delight.
Buckwheat, wheat, oats are for fast feeding and come up first.
Peas, clover are for longer term food source (clover is also for spring green up)
Canola is for late fall, winter for your area.
Shoot straight!
jb
   / I'm slowly learning. (long story) #8
Food plots can be made easily with a disk and an old piece of chain link fence to drag over the disked and seeded ground.
I don't know of any auctions around here. I'll have to look. But hunting, food plots and little tractors are very popular so this stuff goes fast and holds its value. I do check the Ag Dept.'s Market Bulletin.
I agree that a 2 bottom plow would be better. Have heard that the new, low end ones are junk though. Would love to find a good old one in good shape. However, I was surprised to see how well this middle buster worked, it rolled the sod right over, which I'm assuming is what a plow is supposed to do.
The deer down here seem to like anything young, green and tender. They ate my oats down pretty well last year but did not flock to them. But, last year was one of the biggest white oak acorn crops I've seen in 25 years so the food plots were not as attractive. This year we had a late, hard freeze and will have almost no acorns so the plots will be important. This year I mixed clover and greens in with the oats. They won't mess with the greens until after a frost.
I planted cow peas (iron and clay) and sunflowers this summer and they really liked them. Will do that again in the spring.
Not so true in my case. The 'dirt' I have has not been farmed in probably 75 years. The last thing on it was trees. A disk would skid along on top like it was on a cement parking lot. But, with the middlebuster I was able to go down a good 8 inches. Once I've busted them up a few times with the middlebuster or a plow, then the disk will be perfect. It will be my next purchase.
My 'harrow' is a length of chain link fence rolled up around a heavy 6', 6x6 post. I tried dragging it unrolled, but it won't make the tight turns. But, it does great this way.
Flameshield Safety Oil Tank (A59814)
Flameshield Safety...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
