I'm planning to buy a cub cadet ztr but...
   / I'm planning to buy a cub cadet ztr but... #1
mlemire
I\'m planning to buy a cub cadet ztr but...
I'm planning to buy the new cub cadet z force for about 4 600$ but I have a question. I need a bagging system to collect grass but also leaf. Is this ztr attachment comes with a blower or a fan to help leaf and grass to go in the bags??
Thank you
   / I'm planning to buy a cub cadet ztr but... #2
Re: I\'m planning to buy a cub cadet ztr but...
Are you looking at the new Z-Force with a 48" fabricated deck?
   / I'm planning to buy a cub cadet ztr but... #3
Our local homedepot is now handling the cub ztr mowers.
Are these any good ?
They also carry the toro ztr
any opinions on these, I need a mower this spring, my old deere is about shot. and I dont want to buy a throwaway mower, /forums/images/graemlins/frown.gif however that cub sure looks nice /forums/images/graemlins/grin.gif
Ernie
   / I'm planning to buy a cub cadet ztr but... #4
They only carry the RZT, these machines are rated to cut about 1.5 acres. If you have more than that you need to visit your local Cub Cadet dealer or TSC and look into a Z-Force...the RZT's bigger brother.
   / I'm planning to buy a cub cadet ztr but... #5
Thanks Gamble
I only have 1/4 acre to mow, but its a beautiful lawn. will this machine leave a nice cut?
I have tractors to mow the rest of the property with, finish momers, brush hogs ect..
Its priced at $2999 at home depot
Thanks Ernie
www.ernies.net
   / I'm planning to buy a cub cadet ztr but... #6
Well you will love it if you have only 1/4 acre to cut. It is a ZTR so it does have a true floating deck and pivoting fron axle. It will follow your ground a lot better than any ridding mower and you should be well pleased with the cut. I would however, suggest you try to purchase from your local dealer if at all possible.
   / I'm planning to buy a cub cadet ztr but... #7
i bought the z force 44 last year, and love it. I have the bagger too, it works ok. But when you get into the higher wet grass it tends to clogg up. But with nice dry grass works great. The only problem that i have had was that the starter has been acting funny. When you turn the key you just get a click, after you do it a few times it turns. i have brought it to the local dealer, but it still does it.
   / I'm planning to buy a cub cadet ztr but... #8
Sounds like a bad ground. Check for a loose connection at each end of the cable. Next, try taking off the cable and polish it and the terminal up a little. Possibly look at the same things on the + side too.
Good Luck!
   / I'm planning to buy a cub cadet ztr but... #9
Gamble, you're right about supporting the local dealer,
However how do I find a local boy in my neck of the woods /forums/images/graemlins/confused.gif
Im between Portland, and Salem Oregon 97038 zip.
Im not the depot or wall mart type. /forums/images/graemlins/shocked.gif
Ernie
   / I'm planning to buy a cub cadet ztr but... #10
Quick search came up with these results;
FISCHER MILL SUPPLY
20990 SOUTH FISCHER MILL ROAD
OREGON CITY, OR 97045
(503) 631-3411
MAP IT
Distance: 13.9
AG WEST SUPPLY
2929 NORTH PACIFIC HWY.
WOODBURN, OR 97071
(503) 981-0151
MAP IT
Distance: 14.6
LENON IMPLEMENT COMPANY
2175 NORTH PACIFIC HIGHWAY
WOODBURN, OR 97071
(503) 981-1052
MAP IT
Distance: 14.6
STARK STREET WEST INC.
14270 SOUTHWEST GALBREATH DRIVE
SHERWOOD, OR 97140
(503) 625-2967
MAP IT
Distance: 20.4
TROY-BILT FACTORY STORE
39150 PIONEER BLVD.
SANDY, OR 97055
(503) 257-6449
MAP IT
Distance: 22.8
2015 Autocar Xpeditor Tri-Axle Heil 28Yd Front Loader Garbage Truck (A51692)
2015 Autocar...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
1985 FREIGHTLINER FLC DUMP TRUCK (A53843)
1985 FREIGHTLINER...
2005 HACKNEY AND SONS, INC. BEVERAGE TRAILER (A53843)
2005 HACKNEY AND...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
