I'm new and need some help with my John Deere 855 tractor
   / I'm new and need some help with my John Deere 855 tractor #1
Joenicholsonj
Grafton ohio
John Deere 855
Hello,
My name is Joe! I've owned and tinkered with about army thing that has a motor.
It has 1200 hrs on the motor.
The tractor runs and operates perfectly. I also have a model 70 front end loader and model 7 backhoe.
Today I was changing the hydro oil on my JD855 4WD tractor. When I removed the housing for the internal filter that is in the rear end of the tractor, below the PtO, I found a small, 3/4" square piece of cast aluminum about 1/8" thick in the bottom below the wire mesh filter. I don't know where this broke away from and wonder what I should do next. I did use a bore scope and looked inside to see if I could find where it came from but no luck
Any help would be greatly appreciated.
Thanks!
   / I'm new and need some help with my John Deere 855 tractor #2
Welcome from Va, hope you find out that it won't hurt anything!
Thanks! Me too! I have no idea how longs it's been in there. This is the first time I've changed that oil. It's been 3 years and 100 hours since I bought it.
Here is a couple of pictures of the piece.
   / I'm new and need some help with my John Deere 855 tractor #5
Welcome to TBN. Not sure what that is. Hopefully someone will come along and know what it is.
1840 (A51248)
1840 (A51248)
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
15 TON GRAIN BIN (A54756)
15 TON GRAIN BIN...
Mobile toilet with shower (A55758)
Mobile toilet with...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
