IXLR8
Veteran Member
My DK40SEH is starting to drive me nuts with this cold weather. I've been using it to move snow banks and clear the driveway to my shop. The FEL is painfully slow to dump. After picking up a load of snow, when I go to dump it, if I move the FEL control fully to the right... it takes over 20 seconds for the bucket to fully 'dump'. If I just move it to the first position to curl the bucket down... I stopped timing it when it got over 35 seconds. After an hour or two of running, the 'dump' times are cut in half. The other issue, when I go into a pile I am trying to pick up, that is large enough to cause the tractor to stop, and I take my foot off the forward pedal, the tractor keeps driving for 3-8 seconds, time seems fluid temp dependent. If I am in Medium range... it stalls, if I am in Low range.. the wheels just keep spinning. If I press on the reverse pedal, it won't move until the tractor stops driving forward. I have the same issue going from reverse to forward. Again after a few hours of use the times are reduced but still an issue. So right now I have to take my foot off the forward pedal 2-3 feet before I get to the pile and then creep into the pile. Due to this, the DK stalls all the time on me, I never stalled the CK30 that I had. This is getting very frustrating. Especially when I am out in 3 degree weather with 30 mph winds trying to open up our road when the plow trucks cant move the snow. Because the issues are reduced after an hour or two when the fluids get warmed up some. I am assuming if I put in a thinner synthetic fluid I that these problems will be reduced from the start. Presently I have just over 50 hrs on the tractor so it still has the original fluid in it and I am looking for recommendations on what fluid to put in when I do the 50 hr service so hopefully I won't have these problems next winter.
The other issue I am having, not sure if it is related, the FEL seems to be way down on lifting power. Last summer when I tried to lift something too heavy, the rear tires came off the ground. Now, with the same ballast on the back, when I try to lift something 'too heavy', nothing happens. FEL does not lift, rear tires don't lift.. nothing moves.
The other issue I have... I am now getting the DK40 reverse whine! The more I use this tractor, the more I wish I had my CK back.
