Mayor
Did you look at the ones from Loogie's post?
Thanks For The InfoBloomingtonMike said:The KingKutter Carry All I bought from Tractor Supply did not fit the John Deere I Match. I welded on some new tabs that hold the lower pins on - I think they needed to be raised about 2". I left the original tabs in place. Slightly reduces the amount of height I can lift the carry all but it works great. I made a deck out of some 2X3s and bolted the deck to the carry all with eye bolts.
I use it to carry my 25gal Fimco sprayer - eye bolts make it easy to strap it in place. Sprayer gets hooked to the switch controlled cig lighter receptical and then I have a controlled sprayer from the right fender panel. Also extended the spraying wand for spot spraying from the deck for weeds around teh landscaping.
Tractor is a 3320.
