Buying Advice I'm look at buying lawn tractor.
/ I'm look at buying lawn tractor. #1
jagco
PG MD
Not yet
Small hill but mostly flat. I think going to try for I used lawn tractor. 1 craftsman LT 1000 42" cut 18hp not sure of the year, - 2 yard-man 42" cut 20hp model is a T604 about 2004, 3- Cub Cadet Hydrostatic Lawn Tractor, LT1018, 42" cutting width
Briggs&Stratton 31Q777-0305 18.5 HP engine, - 4 John deere 216 16hp 42" cut, - 5 John Deere Made (Scott's) Hydrostatic Drive 16 Horse Power 42 Inch Cut Lawn Tractor, 5 -
Witch 1 guy's you thinking i should buy the pricing range from 450 to 550. all seem to be in good shape. I no nothing about them or use 1 before. "O" man that john deere look sweet though.
I been using a push mower for 3 years this is starting to get harder to do funny.
Thanks will check it out.
I pick up the John Deere 216 runs good the tires all 4 look new and new starter.. Question 1 how do I install the deck and drive belt. Deck Ser - H047K-4578168M has 3 blades. No amp gauge not wired or broke. The light switch is where the choke is for the carb. No lights. Is the 216 4 speed with a revers. Can any 1 tell me what are the little ball levers blue in color and the blue red handle. Witch side is the brake pedal. And what is the other pedal for. "O" there's about 3" of play when i turn the front wheels is this a easy fix. "O" the tractor ser - C or 0 216K-155803N
look through 5 30 2015 025.jpg look through 5 30 2015 033.jpg look through 5 30 2015 040.jpglook through 5 30 2015 037.jpg look through 5 30 2015 032.jpg look through 5 30 2015 044.jpg
/ I'm look at buying lawn tractor. #5
Ive got a Cub Cadet and I'm very happy with it.
/ I'm look at buying lawn tractor. #8
When I got mine, I compared them all. The other mtd brands looked like cheap crap. I was impressed with th quality of the cub. It was made as well as any of the more expensive brands I looked at. I understand that even though cub is owned by mtd, they are built in their own factory and share no parts from the other mtd brands.
/ I'm look at buying lawn tractor. #9
The right side is the brake. The left side is probably a differential lock. The red lever on the left is the throttle. I am not sure what the other red lever does, maybe the PTO engage lever. The black lever with the red tip is the deck height adjuster. Edit, I think the left pedal is a clutch.
/ I'm look at buying lawn tractor. #10
Edit my post!!
/ I'm look at buying lawn tractor. #11
May want to check on recall Cub Cadet LT 1042,1046 etc. models 2009-2012 for hydro transmission problems.
oldpilgrim - I was going between the j deere or the cub - people was saying j-deere parts should be easy to find.
4570man - thanks for the info. This is my 1st with a lawn tractor, I was chicken to even try to get it off the back of the truck. I was able to roll it off with some new ramps I pick up. I start it up and freaken thing took and hit the gate and took it down the gate door - funny after that push up in the yard and park it. Here's few more pictures of it.
Any no where to down load a owner's and service manual for it. From I can see starter looks new, carb looks new, some parts powder painted. It starts right up. Oil looks clean air filter look new.
/ I'm look at buying lawn tractor. #13
If you have made the decision to go with the Deere 216 then I would start a new thread in the John Deere lawn and garden forum. Might get some more information there. Most of the members that are interested in specific models or brands tend to home in on their brand forum.
/ I'm look at buying lawn tractor. #16
just checked...I'm good...thanks for the info.
/ I'm look at buying lawn tractor. #18
I am not a Cub Cadet fan. They just build them cheaper every year. 25 years ago they were almost the equal of John Deere. They are pretty run of the mill now.
/ I'm look at buying lawn tractor. #19
A couple of things that sold me on the Cub:
The steel frame on the Cub is made of much heavier steel than the JD. Really easy to see/feel the difference when looking at the vertical steel plate on the rear.
The mower deck is made of heavier material.
It has a Kohler engine rather than a rebranded JD marked engine.
It has a fabric seat that will not crack like the yellow JD plastic seats do.
I bought mine in 2012. Maybe things have changed since then.
thanks jenkinshp
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
UNUSED RAYTREE RMDM72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
1986 KUBOTA R-400 WHEEL LOADER (A60429)
1986 KUBOTA R-400...
