I'm Ignorant
/ I'm Ignorant #1
rrkr6394
Texas
Iseki Landleader 295
I am not a tractor guy, but I plan to learn.
TA series questions:
1)where is the hydraulic filter
2) where is the hydraulic reservoir
3) transmission fluid and hydraulics the same?
4) where is the hydro pump
5) where do you add/change/check/ front differential fluid
6) there is a plug under the transmission, I assume to change oil, but where do you put it back in
7) and most importantly, what are the winning numbers for this saturdays Texas lottery. That would really help. Thanx
/ I'm Ignorant #2
Well first you gotta pick make and model than we'll go from there.
Texas lottery numbers...sure if you tell me NH lottery numbers. ;)
/ I'm Ignorant
It is an Iseki TA295, 4 cyl, 4wd, 16sp, w/shuttle shift.
thanks alot
As far as the lotto numbers, I think there is a 7 in there, but not sure.
/ I'm Ignorant #4
I'll tell you how mine is, not the same tractor, but might help.
Hydraulic filter is by the oil filter, left hand side, by the oil pan, It's a screen you clean and re-use, don't crush the housing.
Hydraulic resvoir is between your legs when you sit down, also is the tranny fluid.
Hydro pump is maybe inside the torq tube/tranny, maybe on the engine and gear driven?
Front diff fluid. Mine has to have the wheels removed, the knuckles drained and refilled.
Put the oil in back on top, hydro-tranny fluid.
Again, this for mine, your's may be different.
2014 Nissan Murano Cross Cabriolet AWD SUV (A61574)
2014 Nissan Murano...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2006 John Deere 990 (A64126)
2006 John Deere...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
