Tires I'm going to load my tires.
   / I'm going to load my tires. #1
ruralruss
NW Georgia
Kubota B3200
B3200 R4, How many gallons to 75% (top of inner rim) and how many to 50% (level with axle).
Thanks
   / I'm going to load my tires. #2
Maybe some of the service tech members can provide a more accurate answer, but a member responded in one of my threads with this:
Response from RadarTech:
But it seems to me that you just set the bead to the rim with air, and then with the tires on the tractor and the tractor supported to take the load off the tires you rotate the tire so that the valve is at the clock position that is just past the postion would meet the 75% ratio..
Fill the tire until you think it is right, the rotate the tire to 75%, if fluid comes out your done.. If not keep adding..
Of course this could be done with the tires off the tractor too......
   / I'm going to load my tires. #5
Did you see that you can scroll down (within the main window) to "Light Construction Tires" and it list a 12x16.5 as 15.0 gallons. I'd say that is ballpark for 75% full.
   / I'm going to load my tires. #6
They did not list my size either. Call em up and they can tell you.
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
110 gal Sprayer Tank (A50514)
110 gal Sprayer...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
Quick Attach Pallet Forks (A47384)
Quick Attach...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
