I'm building a wood shed....I need some help
   / I'm building a wood shed....I need some help #91
Note to self; never, ever post on a tractor forum what screws I use on my wood shed.....
Why? I would want to know if there where better options or if I used the wrong type of fastener. While I don' think the screws he used will fail, there are better choices that he could have used for the brackets. Cost is going to be about the same, so it's not like anybody was cutting corners. It's just a learning experience that nobody would ever know about if they didn't post pictures.
   / I'm building a wood shed....I need some help #92
It's not a matter of busting on somebody, but it's trying to get you guys to elevate your project to a "Pro" rating. This is what I do for a living and often the homeowner projects are looked down upon by the pro's - often for good reason. I'll try to help and point out the common mistakes so perhaps others will learn and not make them.
I spent some lunch time going through the Simpson catalog to show how the USP fastener pictured earlier should have been fastened. I'm hopeful the somebody will look at the file and learn something from it.
  • Connector.pdf
   / I'm building a wood shed....I need some help #93
Note to self; you can sometimes screw yourself with humor. No pun intended....:)
   / I'm building a wood shed....I need some help #94
Now that's funny!!!
I thought about posting my retirement house build on TBN (after all, I'm shock and amazed at what you guys see in just the photos, kudos...) but couldn't (or didn't) want the... let's say "wisdom" brought to my attention.
Like one builder said to me, you can notice a few problems with what I built... but I could point out a dozen more issues/problems but you can't afford me to build you a perfect house... since then, I don't look at things through a microscope. Yep, that's good enough... I'm looking at crappy sheet rock work right at this moment!!
PS. I think what the builders like Eddie do is great work...
Cord - Thanks for posting that pdf file on the simpson ties.
   / I'm building a wood shed....I need some help #96
It's not a matter of busting on somebody, but it's trying to get you guys to elevate your project to a "Pro" rating. This is what I do for a living and often the homeowner projects are looked down upon by the pro's - often for good reason. I'll try to help and point out the common mistakes so perhaps others will learn and not make them. I spent some lunch time going through the Simpson catalog to show how the USP fastener pictured earlier should have been fastened. I'm hopeful the somebody will look at the file and learn something from it.
Where did you post it?
   / I'm building a wood shed....I need some help #97
Should be just below my post above.
   / I'm building a wood shed....I need some help #100
...Like one builder said to me, you can notice a few problems with what I built... but I could point out a dozen more issues/problems but you can't afford me to build you a perfect house... since then, I don't look at things through a microscope. Yep, that's good enough... I'm looking at crappy sheet rock work right at this moment!!...
While I can relate to what your builder told you, there are the basics in residential construction that beginners get wrong all the time. When a building inspector comes out to a project, he has a list of things he looks for right off on a job. If he sees that all of those basic things are done correctly, he usually doesn't go looking for the little things. But when he sees that some of the basic things are not done properly, he gets nervous and starts to look at everything.
When I see pics of a project on here, I ask myself if it's a significant structural mistake that might lead to a very expensive repair in the future, or if it's more cosmetic and doesn't really matter in the grand scheme of things. I realize that most of the guys on here are just like me in having a limited budget to get as much done as we can. Sometimes we just do things because that's how we saw others do it, or thought we saw it done that way.
I've learned more on here by posting what I've done and getting feedback then I ever thought possible. My mistakes where pointed out by those with more experience then I have, and thankfully their comments saved me thousands of dollars and many, many hours of doing it over again.
It's hard to be told that you did it wrong and then to go back and fix it when you are proud of what you have done. It's even harder to hire a pro to do it for you and have others tell you that your pro is doing it wrong after you have praised is skill set and paid him a lot of money.
I never criticize what it looks like, and usually stop following a thread once it gets into the finished off stage of things. My taste is very specific and I find most people build stuff that I don't care for. In every build thread, when I see mistakes happen that indicate a level of ignorance, I point them out. Sometimes I get nasty emails telling me to not comment. Other times I get emails or comments for more information. If I said nothing, I would feel bad about not offering my opinion when I think that it's wrong. I can't imagine not wanting to hear that form others, and hopefully there will always be plenty of you on here who feel the same.
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
Hay Forks (A50515)
Hay Forks (A50515)
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
