I'm an abuser
/ I'm an abuser #1
DCook
Houston
Case 235
I abused my tractor. Now the transmission is not working. I'm assuming the two are related. Its a Case 235, 3 cyl diesel, hydrostatic trans with a hi and low. My wife was on the tractor about a week after the abusive weekend. She tried to shift it from low range to hi range. She said it made a funny noise. It hasn't moved since. I checked the fluids. The pto works. I've ordered a repair manual but apparently its on the slow boat. Anybody have a spare transmission?
/ I'm an abuser #2
DCook said:
I abused my tractor. Now the transmission is not working. I'm assuming the two are related ... My wife was on the tractor about a week after the abusive weekend.
I'd try to blame her and see if you can get a new tractor out of it:D
/ I'm an abuser #3
What kind of abuse did you subject her to? { The Tractor}.Is it new or did you just buy it?
/ I'm an abuser
I tied a chain to a post and jerked on it REAL hard, a couple of times. Its an older tractor, made in the 80's. I'm eyeing another tractor. A 40's model Cub with a belly mower.
/ I'm an abuser #5
My bet is that jerking on the post did not cause this damage.
/ I'm an abuser #6
I agree, my bet would be shifting from Hi to Lo while moving (and/or while the gears weren't meshing properly). In technical terms, it's "stuck".
Might not be a total disaster, but without more info, it's tough to make a suggestion as how to proceed.
Making a bad noise sounds like maybe grinding gears??
/ I'm an abuser #7
Can you find on the tractor where it says who made it?
I believe it is a Mitsubishi.
Trans or rearend???
Try the differential lock.......easily.
You can take the Rockshaft arm section off in one piece usually, that will allow you to see down into the rear axle area.
Could also be the coupler between the hst and the mainshaft.
If you were pulling hard etc, this could have stripped.
If this is the case, you should be able to lift the rearend and make it work, for troubleshooting purposes.
TAKE IT OUT OF 4WD......first.......:eek:
It won't move the tractor but it will allow everything to move because it won't have pressure on it.
As others have stated, try all the easy stuff first, Hi-Lo lever, 4wd lever.
I have been on a couple of trouble calls that just needed the lever moved, lots of levers can be in nuetral.
Good Luck
BTI
/ I'm an abuser #8
I bought a 3PH backhoe from a farmer that said his Case backhoe would not move. I ask him to show me and he move the lever on the collar to go forward... it moved slightly. Then reverse... again slightly. Asked him about the High/Low shifter on the floor :confused: He said he never uses it... He put it in gear and it worked fine somehow it got kick out of gear and he never thought about it. ;) (not say it's what happen to yours but I would check to make sure about the gears).
/ I'm an abuser #9
D Cook. Your tractor is made by Mitsubishi and is very similar to the Japanese Mitsubishi (grey market) tractors. I have a Mits MTE2000D and just last week had a very similar issue. My son was on the tractor and was moving some dirt and using lo and medium ranges and suddenly the tractor wouldn't move. Turned out that a small pin in the range transmission had broken off. I looked at your range trans on Parts & Service | Case IH and it looks very similar to mine only mine is a 3 speed. The pin I mentioned is on the end of the gear selector handle's linkage ( it is identified as part #3 under the range trans section for your tractor on the CaseIH website) and slides a gear along the main shaft to engage the different ranges. When the pin broke, the gear was stuck between two ranges and thus wouldn't allow either trans to engage. It require removing the seat and some sheet metal to get to the trans but was actually a pretty easy job. I simply welded the pin back and it works fine. Hope this helps.
/ I'm an abuser #10
Does it try to move any at all? I had a bolt on the ring gear on the front hogs head work loose. When it did it would try to move but acted like the brakes were on. ended up rebuilding the whole font axle.
/ I'm an abuser
Yes, Its made by Mitsubishi. And my repair manual came in today. I read through it decided to get busy. I started the tractor, and it moved... about 10 feet. Then it stopped. I left it running about 5 minutes and tried again. It moved another 10 feet, and stopped. It took about 30 minutes but its now in the garage. The manual says there is a screen type suction filter as well as the spin on filter. I did not know about it so its never been changed as long as I have had it. I'm going to do a fluid change and replace both filters. I've seen a few posts about similar problems with the hydrostatic transmission. I'm going to go back and read those posts. Thanks for the help.
dean
/ I'm an abuser
I haven't taken the strainer off yet. Do you clean it or replace it?
/ I'm an abuser #13
I wouldn't blame her very much. If I were you, I would ask her what that sound sounds like. Since I am a female, I have some suggestions: if I was you, I would ask her if she can help you out in buying a new tractor if you can't fix it. I would go to the dealer and ask them for help. But I don't have a spear trasmission. Sorry
/ I'm an abuser #14
I had a John Deere 855, also a hydrostatic and it had a similar thing happen. Check the strainer. When mine stopped, it stopped all at once and it was simply the strainer needing a good cleaning.
/ I'm an abuser
I found the suction screen. It did not look dirty at all. I washed it any way. I'll put it back tomorrow. I have to pick up a spin on filter and more fluid tomorrow.
/ I'm an abuser
I've narrowed the problem to the hi-low range transmission. I believe the shift lever is broke inside the transmission. Major work ahead. Grief. The book says I have to separate the hydrostatic trans from the clutch housing and then the hydro trans from the range trans. Has anybody done this before?
/ I'm an abuser #17
I haven't split that tractor, but they are all pretty much all alike. Just take your time and follow the book closely. The parts are heavy so be ready for that. You will want to do this on a hard smooth surface. Concrete is the best.
You may want to inspect the clutch too. Having it apart it's easy to do!
jb
/ I'm an abuser #18
Sorry, if I am doing this wrong, this is my 1st time, to be able to write on this site. I bought an 855 J.D. from and auction and found the PTO would not stay engaged and the Hydrostatis shift would not stay engage, in reverse. After pressing the forward pedal a few time, I could get the tractor to move forward just fine. Again upon attemting to move it in reverse, the tractor will move a few feet, make a grinding nose, then stop. I have taken it to a J.D. shop in Nacogdoches, Texas. They said the transmittion may cost up to $3500, to repair (yikes). Has anyone had a simular problem?
They said a magnet switch was bad in the PTO, it was replaced and they say it is working fine.
Pappy from Texas
John Deere 2840 Tractor (A64047)
John Deere 2840...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2010 Sellick S-100 10,000lb Rough Terrain Straight Mast Forklift (A68183)
2010 Sellick S-100...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2021 Chevrolet...
PORTA POTTY (A67714)
