ih hydro 86
/ ih hydro 86 #1
dieseldoc13
ih hydro 86
Hello! An answer to your question:
I am a younger mechanic trying to understand older tractors
i have been working on tractors now almost 5-6 years, but this one isn't very familiar in my head, since there arent many around
i have an ih hydro 86 that i am working on for a guy
i recently installed a new charge pump in the tractor (the one that is piggy back and is accessable from the side of the tractor
I also split the tractor and installed a new pump at the front of the transmission i replaced this pump because it gernaded i tested the pressure of this pump at high idle and its about 450 psi
after reassembly and getting the oil levels to a proper level with new filters, i test drove the tractor in high and low ranges, both foward and reverse everything worked...so i thought
i watched the servo pump pressure at neutral, about 200 psi
and about 150 psi while moving, but if the hydraulic lever is stroked the pressure drops to only about 50 psi and the tractor slows down and eventually stops, and once the lever is released the tractor lurches
it will do this in both foward and reverse...i also tested the drive pressures, it is at about 4500 psi at high idle while holding the brakes and starting to move the lever foward while the tractor crawls along
any ideas
/ ih hydro 86 #2
Spend the $90 or so for the genuine IH Blue Ribbon service manual for hydrostatic transmissions. We had a hydro 186 come into the shop and I couldn't believe how cheap the OEM manual is. We didn't need it because the linkage to the inching pedal had backed out on that particular tractor.
Don't ever be hesitant to buy manuals for tractors you have to work on, and ALWAYS price an OEM manual before buying an aftermarket reprint that may be of poor quality and cost as much as the real deal.
/ ih hydro 86 #3
The operation of the hydro's in the IH tractors is quite a bit different then the newer hydro's.
Quite often it is just in the controls and not into the hydro itself unless left operating that way!!!!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Volkswagen Passat Sedan (A61574)
2018 Volkswagen...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
