flyingj
I have a 1983 International Harvester 435 baler. It has been having problems with the pickup cylinder getting bound up. I partially disassembled the pickup cylinder and have found that the (previously repaired) cam that articulates the pickup tines is worn, allowing the cam roller to get over center at one point in it's cycle. I've ordered a replacement cam and rollers from Messicks, however I am having trouble with part of the disassembly in preparation of replacing the cam (Part #10 in the ilustration see URL below).
If you go to Case Ih 435 International Harvester Rectangular Baler (North America) Parts Catalogs and click on "pickup cylinder" there is a parts breakdown of what I'm asking about.
The main shaft in the cylinder that turns the whole pickup assembly has keyways in it near both ends. Two "hubs" (part #3) are attached to the shaft with cross pins and tapered keys (part #21). It appears that these tapered keys are driven in, they have a little hooked part on the inboard end that you must be supposed to pull on to remove the key. My problem is I don't know of any tool that would let me pull it. There is not enough room to get a chisel on the hooked end of the key to drive it out.
Has anybody worked on these? Do you know how I'm supposed to remove these keys? I am close to using the acetelyne torch to loosen things up, but would like to avoid that if possible.
Jim Frisby
Palmer,
Alaska
Jim Frisby
Palmer,
Alaska
