IH B275 Diesel Tractor Hyd Selector Valve Oil leak
   / IH B275 Diesel Tractor Hyd Selector Valve Oil leak #11
Am I correct if I say that I have send you the wrong pics ?
   / IH B275 Diesel Tractor Hyd Selector Valve Oil leak #12
Hello again, that looks more like it, I will send a photo of the schematic that I have been working with tomorrow , just to compare, but I reckon you are right
Trailblaser
Hi DLTTrekkers, looks like you were right on the money, I will pull the valve apart and replace the O rings and let you know how I get on
Trailblaser
   / IH B275 Diesel Tractor Hyd Selector Valve Oil leak #18
Take all the parts that needs o-ri gs to a hydraulic repair shop to match the o-rings up for you.
Hi DLLTrekkers, I am finally on to this job !!! my workshop manual tells me to drain the hydraulic oil before removing the selector valve, I can see why I would need to, can you shed any light on this? maybe more info from your experience??
Thanx in advance
Trailblaser
   / IH B275 Diesel Tractor Hyd Selector Valve Oil leak #20
I have never worked on those and all I have was those pics. So....goodluck with your tractor. Sorry !
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
UNUSED AGT QUICK ATTACH SEEDER DRILL (A51248)
UNUSED AGT QUICK...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
250 GALLON FUEL TANK (A51247)
250 GALLON FUEL...
