IH 986 Universal Ignition Starter Switch Wiring
   / IH 986 Universal Ignition Starter Switch Wiring #1
Mad Mac
Grapeland, TX
Mahindra 5555
IH 886 Universal Ignition Starter Switch Wiring
Greetings:
I bought a Universal Ignition Starter Switch for our old IH 886. The new switch has four terminal posts and four positions. The IH switch has five terminals and three positions. Any ideas how to wire it up?
Thanks,
Mac
   / IH 986 Universal Ignition Starter Switch Wiring #2
Take the universal back and get the right switch, but make sure you keep the nut off the old switch. To replace that nut is like $8. Doing this may cost you a few dollars more now, but what is it worth if you miss wire and burn out something really expensive?
   / IH 986 Universal Ignition Starter Switch Wiring #3
Welcome Mad Mac.
If you can still get the old switch to operate a bit, go around the switch checking which cables and terminal/s have power all the time and mark those cables. Then check which have power at the first position clockwise, then the second, third and fourth (presumably spring loaded). Mark each group of cables seperately and clearly. I suspect one terminal 9and its cables) has the same function as another.
Then on the new switch connect the "power all the time" cables to the input terminal, from there you can progress the switch to find the terninals to which the second and third group of wires need to be connected.
Thank you for your prompt replies. Further examination determined that the fault lay not with the old switch but elsewhere in the wiring harness. My auto parts man was kind enough to allow me to return the unused switch. Most places will not take back electrical parts, but things are different here in a small
town. Thank you again for your help.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2007 Ford Focus Hatchback (A54815)
2007 Ford Focus...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2000 KENWORTH W900 (A55745)
2000 KENWORTH W900...
