IH 806
   / IH 806 #1
Up2
Alberta
(56) D6-9U, (76)Ford 4500 BH, (78) IH 806 D, (08) JD 7330
I have an International Harvester I 806 D. It has given me next to no problems over many years of service, I use it mostly for feeding animals, clearing driveway and pulling the odd log to the sawmill. The other day I noticed it was having some trouble pulling a couple smaller logs and that it was somewhat difficult to shift into reverse. I also noticed that the clutch peddle appeared to engage almost at the top of the peddle movement. I set the clutch up but I still cannot pull anything heavy or start the tractor in motion above second gear. Has my clutch gone or is there another explanation? If it is the clutch I can only find a 104 page service manual online and I can't believe that that will tell me much. I wanted to see the best way to split the tractor if it is the clutch. Up2 my ears in tractor.:confused2:
   / IH 806
I'm starting to think something hydro-static because there does not appear to be any slippage. Anyone familiar with adjustments to the hydro=static?
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2003 STERLING ACTERRA ROLLBACK (A51222)
2003 STERLING...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
