IH 706 shifter problem
/ IH 706 shifter problem
Just thought I would ask on this forum, does anyone know any details about a 756 shifter kit upgrade to this unit and what that would involve changing and cost? Would it be something to look into?
Cory
/ IH 706 shifter problem #12
Changing up to a 756 or 766 gets pretty involved and expensive!!! You can get this one right, just be persistant.
The bearing I am talking about is almost directly in front of the steering wheel and is under the sheet metal between the steering wheel and the fuel tank sheet metal. Take that off and you will see what I am talking about. Make sure all the parts in the shifter are good before you start going crazy.
Also make sure the clutch and the T/A are adjust properly.
Almost all of the time getting these things right will take care of the shifting problems. Owning any 06, the shifter just kind of comes with the territory.
2 problems so far, needed washers between the 2 shifters for side to side play now for the front to back sloppiness (about 4 inches) down at the botton where this shaft pivots, theres a clamp that needs tightening around this shaft which connects to the arm to change the range shifting below my feet. With this clamp tightened, it will illiminate alot of slop and the range shifter will move alot better. After this I think I'm going to check the clutch and TA adjustments!
Well, it's shifting alot better, even without checking the clutch and TA adjusted yet. I can actually shift on the fly, amazing!
2015 John Deere CX15 (A60462)
2015 John Deere...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A61307)
2023 Top Air ATV...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
Kubota L4701 (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
