IH 706 shifter problem
   / IH 706 shifter problem #1
succor
Saskatoon, SK, Canada
foton 254
Hi everyone, I got a 706 diesel with a shifting issue. First of all, very hard to shift between gears, secondly, going from low to high is very hard, almost hit and miss to get it to go, you really have to be rough with it. Previous owner had a loader on it which is now gone as I don't need it. I'm gonna start hunting for a manual but also thought I would gain some expertise from this forum as well. Where should I start looking or if anyone has pictures would also be very helpful to see the mechanics of operation.
Cory
   / IH 706 shifter problem #2
Sloppy, worn out external shift linkages.
Transmission brake, clutch and TA linkage out of adjustment.
Missing/worn linkage parts under the transmission range cover.
I got a manual ordered off ebay so I can start troubleshooting the issue. Thanks for the info
   / IH 706 shifter problem #4
Succor, start by taking the sheet metal cover off right in front of the steering wheel. You will have to take the T/A handle, and the climbing handle off. This will expose the top of the linkage. Just check it out to see that everything is tight, and that the bearing at the top of the trans shaft is actually working in some way. Do you have the T/A in direct or cut back position? Old timer trick, pull the T/A back and see if it shift better then. This would be an adjustment on the T/A linkage or the clutch.
Wow, I will try that Barry, thanks for the tidbit. I've used the TA but I don't think I shifted with the TA engaged, it's in direct right now. I sure do like this tractor, it's strong for a 72 hp.
   / IH 706 shifter problem #6
What engine do you have 282 or 310? Most 282's have been turned up running more like 80.
It's a 282, I don't know the actual HP of this machine, that's what I read from specs but it sure pulls like a JD 4010.
Hey Barry, I set the TA on so it's out of direct drive and it does't shift much better either. I'm not sure about the bearing you're referring to until I get the service manual to see a visual. I'm gonna start playin around with the adjusters a bit to see if I can improve it but also to see how it works.
   / IH 706 shifter problem #9
If you go to Case IH 706 INTERNATIONAL TRACTOR you can look at parts diagrams to see how it is put together until you receive your manual.
Hey thanks Darryl, I will use this to get started.
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2023 JACTO ARBUS-1000 LOT NUMBER 69 (A53084)
2023 JACTO...
378499 (A51573)
378499 (A51573)
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2017 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2017 Chevrolet...
