IH 595 tractor PTO problem
   / IH 595 tractor PTO problem #1
NelsonP
Case IH 595
After an hour or two PTO stops working if I put tractor in reverse it will work again for awhile then stop completely if I stop the tractor for four or five hours it repeats the same cycle. Also just lately the PTO keeps turning slowly when not engaged , any help would be appreciated, thanks.
   / IH 595 tractor PTO problem #2
This sounds awfully similar to how my Mahindra 3616 acted when/right before the one way pto clutch failed. The pto would stop under use at times, restart after a slight reverse. And the shaft would spun slowly but could be stopped by hand. I'm not sure of anything on your model. But now I'm going to look into it.
   / IH 595 tractor PTO problem #3
That series IH tractors had no one way clutch. Only a hydraulic clutch pack, which in this case I believe is suspect. Losing power to drive a load could be a low/insufficient pressure problem, but the creeping when turned off symptom is more likely a result of some mangled clutch drive discs. The drag between the clutch plates is overcoming the brake plate so the unit continues to turn. I see a clutch pack repair in your near future.
   / IH 595 tractor PTO problem #4
I looked into this tractor after my initial post. Noe I see that my post has no value.
2 Yard Commercial Dumpster (A49346)
2 Yard Commercial...
1999 Ford F-150 Pickup Truck (A48081)
1999 Ford F-150...
3-Point Water Well Drill w/Drill Pipe (A50860)
3-Point Water Well...
2019 John Deere 317G Track Loader (A50490)
2019 John Deere...
2015 Ford F-350 Service Truck with Liftgate (A48081)
2015 Ford F-350...
2019 PETERBILT 348 TANDEM AXLE 22FT REEFER BOX (A50505)
2019 PETERBILT 348...
