IH 574 gas winter oil
   / IH 574 gas winter oil #1
Barlow96
Pa
IH 574 gas
Hi everyone,
Sorry if this has been discussed but what would be the best oil for my IH 574 gas for heavy use in the winter temps 10-32 degrees? The manual says 10w but all I can find is non detergent. Is there an acceptable alternative weight such as 15W-40 or what is a good brand of 10W?
Thank you
Brandon
   / IH 574 gas winter oil #2
SAE 10W Low Ash can be found at Case IH dealers.
Might be able to order SAE 10W at other places such as ChevronTexaco.
If you do use a 10W-30 or a 15W-40. make sure it's heavy-duty and has both an "S" rating and a "C" rating and check the oil reguarly.
   / IH 574 gas winter oil #3
I have the Industrial version of the 574 mine is Int 2500 i use only Pennzoil 10w30 Winter and Summer works great.
1999 Hypac C-766 66" Double Drum Vibratory Roller (A52384)
1999 Hypac C-766...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
UNUSED RAYTREE RPRB72-72" POWER RAKE BUCKET (A51248)
UNUSED RAYTREE...
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
100 Gal Fuel Tank with Pump (A51573)
100 Gal Fuel Tank...
