IH 500C Oil From Vapor Tube
   / IH 500C Oil From Vapor Tube #1
wanobby
I hope this is the correct forum, but since there are other IH questions here, I thought I would try. My neighbor has an IH 500C track loader and it runs great, but after it warms up and has been used to 15 to 30 minutes, oil seems to come from the vapor tube that comes from the oil fill cap then drips steadily. Under the cap is a baffle that sits just below the cap and is held in place with a spring. We are sure this is supposed to stop the oil and allow the vapors to escape, but there is evidence of oil above the baffle, and inside the cap.
We are thinking that either the baffle is leaking as we can see light through it and do not know if this is normal. Or possibly oil is building up at the top of the motor and not draining properly or fast enough back down into the crankcae, and thus flowing out the top of the motor thought the baffle, and out the vapor tube.
Do either of these seem reasonable? Has anyone else had this issue, and can share their experience or suggestions? The motor is strong, and starts right up, and has plenty of power with no extra smoke than normal. Thoughts?
   / IH 500C Oil From Vapor Tube #2
What is the rate of oil consumption?
According to my neighbor, once it starts leaking, it has a steady stream about half the size of a pencil coming from the vapor tube. He thinks that maybe it would equal about a cup of oil in about a minute. This was why I was thinking that it might not be draining properly back down into the crankcase, but since I don't know very little about the engine other than it is yellow, I would hate to assume anything.
434669 (A48836)
434669 (A48836)
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
2019 UTILITY...
1996 CHEVROLET IMPALA SEDAN (A52576)
1996 CHEVROLET...
