IH 484 Stopped ?????
/ IH 484 Stopped ????? #1
cordwoodlar
Hilton, NY
IH 484, Oliver 88
I just bought an IH 484. Diesel, 3 cyl. I was going down a field lane and hit a bump over a drain tube in the field. The engine slowed down and finally stopped in about 100 yds. No smoke. It sounded like it wasn't getting fuel. It will start and run only momentarily. Could it be the fuel filters? I haven't used the fuel that was in the tank when I bought it yet. There is about 4 gal. left. Should I change both, the primary first, run it a bit then the secondary, drain the tank and change both or what. I have run about 5 gal through it since I bought it. Thanks for the help. Diesels are new to me.
/ IH 484 Stopped ????? #2
I always approach repairs from the simplest first. I would change primary first. If it corrects the problem I wouldnt go any further. If not then change your final filter. However if filters are cheap to you then change em both.
/ IH 484 Stopped ????? #3
I would start at the tank. Does this have the tank that is part of the fender assembly? I would make sure the intake does not have crude over it. There is a shutoff on the bottom of those tanks. You can back the shutoff clear out and it should run fuel. If it doesn't you have found the problem.
/ IH 484 Stopped ????? #4
While you are there, check to see that you have a good fuel flow. We have even had to remove tanks to turn them upside down to get the crap out!
/ IH 484 Stopped ????? #5
Have a look @ this info , it will help you !!!!
  • IH Fuel Problems 74-85Lseries.pdf
  • 84series L cab & Noin cab fuel pipe assy.pdf
2008 Peterbuilt  Semitruck (A64047)
2008 Peterbuilt...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
(2) STAINLESS STEEL SINKS (A63745)
(2) STAINLESS...
2018 Bobcat S-570 (A63118)
2018 Bobcat S-570...
