IH 484 clutch shaft wear question
   / IH 484 clutch shaft wear question #1
southms
Jackson,MS
International Harvester
Hello folks.
The clutch on my ih 484 got stuck so I split my tractor to get it freed up. When I opened it up I was unable to move the throw out bearing back and forth. It appeared to be all the way back toward the transmission but pedal was still stuck to the floor. I also discovered that the splines on the shaft where clutch sits are worn about 50%. I want to replace that shaft but unclear on how to remove it. The manual says I need to open the top of transmission but I don't see where I can open the top. Maybe bottom....?
Anyways, I am asking for some expert advise. I need to remove this wore out shaft and free up the pedal. How should I proceed with this?
IMG_20180518_112014_resized_20180521_122209511.jpgIMG_20180518_110437_resized_20180521_122210456.jpgIMG_20180518_110450_resized_20180521_122207862.jpgIMG_20180518_102916_resized_20180521_122209138.jpgIMG_20180518_110341_resized_20180521_122210095.jpg
   / IH 484 clutch shaft wear question #2
   / IH 484 clutch shaft wear question #4
Looks to my that its frozen with rust on one pic and oily on another pic .
Remove rollpins going thru that shaft....remove bearingcarrier then clutchshaft.
To replace splineshaft ...loosen 3 bolts and wiggle shaft to temove releasebearingcarrier ....then wiggle splineshaft and pull out.
Remember to replace all seals.
There is a spesial tool to adj the pressureplate fingerhights
   / IH 484 clutch shaft wear question #5
The topcover is to reach the gears in the gearbox and not the releasebearing !
DLTTrekkers, Thank you for reply.
I took a picture then sprayed everything with transmission fluid mixed with acetone - that's why it looks oily.
So the three bolts you are referring are the ones I marked with red and roll pins marked with green on the following picture?
   / IH 484 clutch shaft wear question #7
Thats correct !
I will make a pic of the finger adj tool...take a phot and upload it if you need it ?
Thats correct !
Please do! I would love to see the photo of the tool
Deere 9965 Cotton Picker (A53472)
Deere 9965 Cotton...
2017 Ford Explorer SUV (A51694)
2017 Ford Explorer...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
