IH 484 clutch shaft wear question
   / IH 484 clutch shaft wear question #1
southms
Jackson,MS
International Harvester
Hello folks.
The clutch on my ih 484 got stuck so I split my tractor to get it freed up. When I opened it up I was unable to move the throw out bearing back and forth. It appeared to be all the way back toward the transmission but pedal was still stuck to the floor. I also discovered that the splines on the shaft where clutch sits are worn about 50%. I want to replace that shaft but unclear on how to remove it. The manual says I need to open the top of transmission but I don't see where I can open the top. Maybe bottom....?
Anyways, I am asking for some expert advise. I need to remove this wore out shaft and free up the pedal. How should I proceed with this?
IMG_20180518_112014_resized_20180521_122209511.jpgIMG_20180518_110437_resized_20180521_122210456.jpgIMG_20180518_110450_resized_20180521_122207862.jpgIMG_20180518_102916_resized_20180521_122209138.jpgIMG_20180518_110341_resized_20180521_122210095.jpg
   / IH 484 clutch shaft wear question #2
   / IH 484 clutch shaft wear question #4
Looks to my that its frozen with rust on one pic and oily on another pic .
Remove rollpins going thru that shaft....remove bearingcarrier then clutchshaft.
To replace splineshaft ...loosen 3 bolts and wiggle shaft to temove releasebearingcarrier ....then wiggle splineshaft and pull out.
Remember to replace all seals.
There is a spesial tool to adj the pressureplate fingerhights
   / IH 484 clutch shaft wear question #5
The topcover is to reach the gears in the gearbox and not the releasebearing !
DLTTrekkers, Thank you for reply.
I took a picture then sprayed everything with transmission fluid mixed with acetone - that's why it looks oily.
So the three bolts you are referring are the ones I marked with red and roll pins marked with green on the following picture?
   / IH 484 clutch shaft wear question #7
Thats correct !
I will make a pic of the finger adj tool...take a phot and upload it if you need it ?
Thats correct !
Please do! I would love to see the photo of the tool
1985 Ford Ltl9000 Tender Truck (A53472)
1985 Ford Ltl9000...
2017 AUTOCAR YARD SPOTTER / TRACTOR (A52576)
2017 AUTOCAR YARD...
Craftsman 917.257632 42in Riding Mower (A51694)
Craftsman...
2023 John Deere 324G Skid Steer (A53342)
2023 John Deere...
