IH 434 stuck in third gear
   / IH 434 stuck in third gear #1
bmorelectric
mississauga
harvester international 434
My 1968-70? IH 434 is stuck in third. It seems the shifter should be in neutral with play moving side to side but it is in third. When I shift to other gear the tractor will not move and will stall. I was going to take off the shifter housing and then I realized I have to remove the hydraulic valve housing because the bolt hits the hydraulic housing. I am looking at the this properly? If I do have to remove the hydraulic housings is there any this I should be away of? Also when I set up the shifter lever on the gears is there anything I need to do? Thanks
   / IH 434 stuck in third gear #2
I have a similar gearbox related problem (1 and R stuck) and also realized I can't get the top lid off due to the bolt under the hydraulic block. Any success?
I will let you know in a couple weeks. I had remove hydraulic housing with a chain block . Aligned the forks on the gears, thought I had it, lifted housing up to put gasket sealer on it. Tried it and was stuck in reverse. Returned home and I will try again. What a pain
   / IH 434 stuck in third gear #4
once you remove the cover and shifter linkage/shaft u have to move the slides in the transmission to neutral ( i usually do this with a small pry bar or large screwdriver ) which will remove the tractor from being in whatever gear it is stuck in, once you do that the tractor should move easily - test by rocking back n forth or pulling on it with another vehicle - once you verify that, put the shift linkage/shifter back on and it should be back to normal. Usually this happens as a result of worn slots/shifter rod
I will try it on Saturday, what a pain. I will let you know how I made out. Thanks for the input and help
1989 Miller Legend AEAD-200 LE Towable Welder Generator (A55851)
1989 Miller Legend...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2015 VOLVO VNL760 SLEEPER (A57880)
2015 VOLVO VNL760...
2014 JCB 930 (A53317)
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
