ih 37 baler
   / ih 37 baler #1
amberwave
wapak ohio
ih 37 baler
I have a problem with the plunger, or pitman arm not being correct. The stroke is to short on pitman arm and plunger bottoms out. I need to know a measurement of pitman arm to see what is wrong. I know nothing about this baler aquired as is and previous owner gone. Any help i can get to fix problem would be grateful.
   / ih 37 baler #2
I dont know how the stroke can be too short, since it is a constant controlled by the throw of the crankshaft driving the pitman arm. ... Do you mean the plunger is hitting a stop in the chamber preventing a full stroke of the plunger? There is a shearpin behind the flywheel that will shear off when this happens. The stop is a safety device, which if triggered must be reset to resume normal operation.
   / ih 37 baler
plunger hits the front of baler {fly wheel }. I think someone has repaired it with the wrong part just not sure if its the plunger or pitman arm . if i pull center bolt out of pitman arm i can spin baler over and when plunger bottoms out pitman arm spreads 2.25 inches apart .
   / ih 37 baler #5
The pitman on my I37 is 38" center to center.
2021 SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
2021 SELLICK...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
UNUSED CHERY INDUSTRIAL 10' CORRAL PANELS (A51248)
UNUSED CHERY...
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
2019 Polaris Ranger 900XP 4x4 Utility Cart (A51691)
2019 Polaris...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
